Road Race/HPDE Evo 8 track-ability
Old Jun 16, 2015 | 10:37 AM
honda-guy's Avatar
Hondabond #1
Old Jun 16, 2015 | 12:03 PM
TSiAWD666's Avatar
Hondabond is unbelievable stuff.
I don't track my evo but I have kept up somewhat with track folks and talked to fellow Evo time trial guys over the years (so that I might have a head start if I ever totaled my current race car). The two things that come to mind in regards to mods needed for a track Evo 8/9 are:
1) camshaft position sensor heat shield (moreso if your exhaust manifold is not properly shielded)
2) front lower control arm ball joint heat shield
Old Jun 16, 2015 | 12:29 PM
Balrok's Avatar
Aren't all of those OEM's of Threebond?
Old Jun 16, 2015 | 12:57 PM
honda-guy's Avatar
you'll definitely need heat shield for lower ball joint and tie rod if you remove the rotor heat shield for brake ducts.
Old Jun 16, 2015 | 12:58 PM
drsrock's Avatar
Originally Posted by mouseIX
What are your exact plans and power goals? Street tires or R-comps?
A car that I can drive on the street but beat the crap out of at the track. Prob will be on Rivals or equivalent tires But may end up on slicks.
Old Jun 17, 2015 | 09:56 PM
boostincincy's Avatar
If you're possibly looking for an evo IX, I'm probably selling mine. Basically just a DE car that I drive to/from the events. Doing a two day event at Lime Rock next month, and that might be the last event for her before I put it up for sale. Have had zero issues since buying it in 2008, and I feel I've gotten it to a great point of being drivable on the street but feels balanced and predictable on the track.
Old Jun 18, 2015 | 08:10 AM
honda-guy's Avatar
^ we'll be at LRP with nasa in july 3-4 also
Old Oct 20, 2015 | 05:29 PM
Nimpoc's Avatar
I've been digging for these nuggets over the years and kinda came up with the following list in order of perceived importance; wished there was a sticky. My chick and I HPDE my ~300whp DD typically back to back so ~40min duty cycle in the faster street car groups (NASA 3/4, etc).
0. Obvious, but make sure you've done all the maintenance on the car (all hoses, belts, seals, good fluids, boost leak check -> throttle seals, fuel pump / filter, and probably EGR delete). The cars are getting old. I had a rubber turbo water line let go which was a bummer.
1. Older cars will likely have beat intercooler (oil coated interior) & oil coolers (flat fins), probably should replace those.
2. Seems universal to run a Kiggly HLA and overfill a bit at minimum for oil control.
3. This might be more specific to Californians with our awesome fuel, but do as much as you can to reduce back pressure and get a safe tune. Not suggesting this for power, but reliability. Also enable the knock CEL so you can curb the enthusiasm if the motor gets too hot. We've run the fuel tank pretty low and haven't seemed to have any issues.
4. When getting a tune consider SD so you can make it off track when you pop an intercooler pipe. Had to get towed for that once, managed to limp off other times.
5. Everyone has their brake pad opinions; we're on PF08s / centric blank rotors and probably should have cooling but don't yet. The rear brakes don't seem to do much at my level. ABS is amazing to me on split mu surfaces, curbs, etc...
6. As stated before insulate the lower ball joints. I threaded safety wire thru header wrap then wrapped it in metal tape. Seems to be working well. Also if you're running a roll center kit you can get the superior factory rubber boots vs. crap white line bits.
7. I've tried a couple tranny fluids and found the factory 6-speed stuff to be the best shifting. Be sure to do the clutch adjustment procedure to save your syncros since you'll be shifting at high revs all day. Also when the clutch comes out install the ACT Monoloc. We had the TO bearing come loose and had to drive the car 5-hours home w/o the clutch once. Lastly, replace the front motor mount to get some of the drivetrain lash under control.
8. There's a thread for tow hooks. I've not suffered too bad not having one yet, but did see a car pulled by the A-pillars a couple events ago.
9. Re-stack the rear diff. Consider having the transfer case serviced and big bolts installed. Jack's installed a used front RS LSD for +$200.
10. Stock suspension handles 'well' but eats tires. This is a very personal decision but I'd advise going straight to quality coil-overs (AST, Ohlins) and both swaybars. In my experience the rear bar alone sucked, leading to understeer all over the place. I'd also advise being selective if electing to install aftermarket bushings. For the most part the stock ones have a nice performance vs. NVH balance.
Old Dec 3, 2015 | 11:13 AM
kyoo's Avatar
Originally Posted by Creatre
I was PM'ing with Balrok a couple months ago about this. Here's what he said. Hopefully he'll see the thread and chime in more:
"As far as the two pans, the Bush pan doesn't add but 1-2 psi so it's worthless. The AMS pan leaks no matter what you do so i'm not too impressed with it. There is an option in NZ but we haven't seen it stateside yet."
For now I'm currently just overfilling a bit. I'm not on rcomps, only 255 rs3, so hopefully the pressure loss isn't overly bad.
are any of you guys with the kiggly hla still experiencing oil starvation?
^^ not as much comment as I would have thought on brakes/cooling above. are we ok with good fluid and aftermarket pads? no need for any ducting etc for the 350whp and down range?
Old Dec 3, 2015 | 11:50 AM
honda-guy's Avatar
yes, i still get oil starvation with kiggly on long right hand turns but not as bad as before. about 10-15 psi difference.
Old Dec 3, 2015 | 12:13 PM
kyoo's Avatar
what tires? your car is pretty set up and bad *** if I recall correctly, a bit different from my mild boltons plus coilovers evo.
general question: what does the car/engine do when it oil starves?
Old Dec 3, 2015 | 12:33 PM
kaj's Avatar
kaj
A completely stock Evo VIII is just fine. I ran mine all day without any problems (Buttonwillow). I do suggest pads and brake fluid in case you are aggressive. There's nothing more disappointing than having to cut the session short due to brake fade.
No need for all the fancy stuff or to over think it.
I even used the same wheels and tires I drove to the track on and had a blast.
Old Dec 3, 2015 | 02:09 PM
kyoo's Avatar
I started smelling a little fluid at the end of one my sessions, stock calipers with ferodo ds2500s.. it was probably my old *** brake fluid though. Just making sure, better safe than sorry!
Old Dec 3, 2015 | 02:28 PM
killerpenguin21's Avatar
You can easily cook the seals in my opinion. Ever since I went to the rb stainless Pistons I replace my deals at minimum once a season but usually more, and I still get some weeping when cold
Old Dec 3, 2015 | 04:44 PM
kaj's Avatar
kaj
I did change fluid annually. Now its twice per year since I've gotten competitive.
Those pads are okay. My first track day was with OEM pads. I wasn't happy LOL.
Other than that, just go and enjoy yourself. Even with all OEM stuff, I had a ton of fun, I just wasn't setting any lap records LOL
