Hard nose dive under threshold braking
I can add a ton of anti-dive with my billet arm setup though currently havent made anything long enough for the X. Carl (MeatHooker) has my arms and Im pretty sure he's running them in the anti-dive setting. That seems to work well for track and aero but in AutoX it causes some push at high steering angle. So I run mine neutral. Just another level of adjustability I add
And the PSRS (or other brands) offset bushings that allow you to add anti-anti-dive is actually mandatory if you are low enough. You cant get to the anti-dive side of things with the offset and being low because you'll hit the chassis (unless you clearance it) with the bushing bore and likely break the arm.
jameswwt
10
Dec 22, 2011 12:19 PM
EVO8speed
May 5, 2005 10:58 AM
