evo 4 - 6 and evo 7 - 9 axles different?
Old Feb 24, 2019 | 01:00 PM
Bee-Raddd's Avatar
Hey All,
Are evo 4 - 6 and evo 7 - 9 RS axles the same length or different? im talking RS not AYC axles here.
Keep hearing different things. And while we are on the topic are the X RS axles different again or all the same?
Also does anybody have any actual knowledge on the inner workings e.g is evo 4 - 9 CW and Pinion the same but evo X stronger as ive been told? or are evo 4 - 6 CWP different from E7-9 also
Any thing else internally that is different between 4 - 6 and 7 - 9?
Old Feb 25, 2019 | 07:35 AM
Balrok's Avatar
What's the goal? I don't think any of them are interchangeably bolt-on. For instance the X's are longer then the 7-9's. The best bet is to have custom ones like DSS axels if you need something longer/stronger etc. (yes she said).
Old Feb 25, 2019 | 09:29 AM
Bee-Raddd's Avatar
i wana convert from AYC to RS. Its alot cheaper to get a 5 - 6 RS rear end with diff and axles than it is to import a 7 - 9 one from ebay. Hence why im trying to figure out wether the axles are same or not as some people say they are same others say they are shorter than ct9a axles
Old Feb 25, 2019 | 02:35 PM
alpinaturbo's Avatar
Since rear end is identical, axles should be close enough. Try MLR lancer Register, for info: use search feature under Gearbox Transmission forum section.
Old Apr 9, 2025 | 03:00 PM
Playero36's Avatar
I am looking to swap my evo 6 with rallliart diff.
Are the axles for ralliart diff the same as evo 5-9 RS?
