oil temps
has anyone upgraded the oil coolers on their cars? my oil temp goes up to 120C (or a little past that) during HPDEs and i'm wondering if i need to or should upgrade anything.
thanks |
I hit 120c regulary at the track. I saw 135c+ 3 weeks ago at buttonwillow in 97F+ heat but that's because my head studs got cranky and decided to stretch. :eek:
One thing to keep in mind is your water temps go hand in hand with oil temps. 128c+ oil temps is when you want to slow down. It really depends on your oil type too. Some are ok to 140c I use a 10w-30 and 20w-50 oil cocktail to be safe. |
I did my hottest road racing this past weekend (90+) in La Junta, CO, and I was peaking at 110C*. It was a 1.5-mile course that was very fast to the point that I was averaging 92.3mph on my best lap while running 25-26psi. 110C is the highest I've seen it go in any occasion. At my last track event in March, it was only 50-60* outside, and my temps stayed at 100C or lower. I have no upgraded cooling items - stock FMIC, stock radiator, stock oil cooler, stock Mobil 1 oil, etc, but I do spray alky, which cools the intake charge.
kzevo, where is your temp sender located?
that makes a difference... n |
When I HPDE my Eclipse, my oil temps get to be pretty high. First few runs were ~230-240*F, and by the end of the day the gauge was maxed out a little past 250*F. Getting way up there... I am still on the car's stock oil cooler and from what I've ready, 2g oil coolers suck. I should upgrade it but I'd rather put the money into my Evo, but we'll see. I had AMSoil 1030 synth. in there which is good oil. This was going around Mid-Ohio, which is ~ 2.25 miles which has that nice long straight...
Hell, my oil temps get to be ~ 230 on hot days battling traffic on my way home from work. What did you mean buy water temps and oil temps go hand in hand? My water temps were pretty stable the whole weekend not going above 210, though the oil temps kept rising as the day went on. Just because one is rising doesn't mean the other will do the same. |
I noticed a difference between the two on my MR. |
n - the oil temp sensor is located in a sandwich adapter that mounts to the oil filter housing.
there are 2 plugs by the oil filter plate.. one is before the oil cooler & the other is right after the cooler... so depending on where you put the sensor you will see dramatically different temps.... I am assuming you put your after the cooler.
Mine is located before the cooler, so I see the very hottest temps the oil will ever see..... 140c during hotlapping. n |
on my old 03 EVO I used to be at 260 F easy
Mine is located before the cooler, so I see the very hottest temps the il will ever see..... 140c all day. n |
Originally Posted by razorlab
Where did you put yours on the filter housing? I put mine in the upper spare input. Not really sure if that is before or after the cooler. I should have payed more attention. :updown:
n |
Originally Posted by meanmud
140C - that's testing a good synth; change it out after each event?
n |
