Aftermarket steering wheel
I need a quick-release steering wheel setup. It looks like I will need a hub? Do I get the "short hub" since I need to add a quick release? Do certain hubs only work with certain quick releases? and do all quick releases work with all steering wheels?
I'm thinking it goes: steering column-> hub -> quick release -> wheel I'd like the wheel to end up about where it is, stock. I plan to use a Sparco wheel, so whichever bolt pattern that is. Thanks, in advance. |
I am also interested in this.
If no one answers...I will take a pic of my setup for you
I have the personal steering wheel and forgot what hub ...but i do have a brand new SPARCO wheel still in the box. Once I get off the road on Sunday I will get pics...I may have the whole setup in the hauler. Message me if I forget, I'm old and forgetful lol |
I'm old and will also forget LOL.
I was able to retain my seatbelt, so need my airbag. But I'd like to know just in case. |
Ya pretty much just a short hub. I forget which one mine has but i'm using the OMP wheel with the straight bottom. There's a write up here: https://www.evolutionm.net/forums/ev...l-install.html
Edit: Mine is a works bell short hub. |
Just went though this my self. Can't set up a quick release without an aftermarket hub. I Bought the aftermarket Hub from NRG, and their quick release set up. Found it on Amazon for about 200$ total. It sounds like there are better options out there band wise, but I was in a bind at the time and the quality has been good in my opinion.
Okay, that's what I was finding. My only other concern is does the quick-release hub fit all steering wheel bolt patterns? I saw hubs for specific wheels.. so not sure if i need a specific quick release.
I used this video when i was installing my bew Steering wherl but is not a quick release
https://www.youtube.com/watch?v=lT7zfVEPkqg looks like is very straight forward. |
I didnt search, but if there isnt, it'd be good to have a thread to show steering wheel setups.
Most off the shelf tuner quick releases will fit many varieties of wheels. I run a works bell aluminum hub with a NRG short QR and a deep corn Nardi (Ive also fit a momo, personal wheel on the same QR)
Originally Posted by Kidloco51
(Post 11701459)
Bumping this up. Anyone know if an after market wheel/hub will work with the OE clock spring for ABS/ACD?
Originally Posted by V.8MR
(Post 11772551)
George |
bell on my 9 works as intended.
