Volk ce28n help!!
Old Nov 3, 2008 | 04:06 AM
YeaIbOOst's Avatar
Volk ce28n help!!
hey guys I came out to my car this morning and both my driver side front and rear tires looked low. So I took the valvstem caps off to check the pressure and air is shooting out. I played with the pin a little and the air won't stop. I'm leaving for vacation for a week am I gonna come home to bent rims? Anybody recommend any tire shops in central jersey area ?
Old Nov 3, 2008 | 06:58 AM
SoR's Avatar
SoR
It seems to be your valve insert. I had the same problem on my Gram Lights.
Buy a valve tool and screw in the valve insert tighter or just replace it all together.
You can get a kit in stores like Pepboys for like $5-10.
Otherwise, where in CNJ are you? PM me.
Old Nov 3, 2008 | 08:45 AM
chaotichoax's Avatar
go to a tire shop they have a tool they'll just tighten them up
Old Nov 3, 2008 | 08:47 AM
donbrown34567's Avatar
+1, just let em know whats up and they should be able to just run out and tighten em up for you. as for the whole bent rim part, idk, i would just run the car to the tire shop asap haha
Old Nov 3, 2008 | 08:53 AM
kyriptic's Avatar
Even with some needle nose pliers should be enough to turn the thing inside and tighten it (incase u need the car) Happened to my CE28's too once and just tightened it and no more problems, you should get a tool though and make sure you tighten it good.
Old Nov 3, 2008 | 08:57 AM
DarksideEng's Avatar
Once you tighten them they will be fine. Your CE28s will not get bent from the tires losing their air. Now if you go driving over curbs with no air in the tires, its a different story .
Old Nov 3, 2008 | 06:30 PM
EatSleepBoost's Avatar
sounds like u need a valve core tool and some good old compressed air.
Old Nov 8, 2008 | 03:52 PM
YeaIbOOst's Avatar
thanks for all the replies guys. I just got home and the tires aren't flat..i guess the caps held all the air in. Im gonna go to a local store tomorrow and try to see if i can find the tool. thanks for all the help
