help needed
Old Mar 13, 2009 | 06:07 PM
Spirit evo 8 MR's Avatar
help needed
i do not know if you can help me.. but i have a little problem.. seems that i can not get my aem tru boost programed right, ether spring press. is too high or too low causes car to over boost in third gear, when stepped on, but is normal when driving easy.. i have spring press set on 11.0 points, boost setting is A48. sometimes the gauge reading jumps all the way to the 23-24 PSI maybe more and then drops down and holds around 18-19 psi, sometimes 20psi, i am running stock turbo and trying to figure out how can i enter the setting the way where i will get about 19-20 psi... also i notices today that as RPM increases the boost does it too around 5000 6000 rpms, then it over boosts and shuts down.. as you see i am kinda new with this stuff and new on this web site too, so any help will be appreciated. thanks
