Beta testers for reflash
The reflash machine is in and I just completed my training from the manufacturer.
I am ready to start taking appointments and will offer very reduced pricing to any tri-state members who want to be beta testers. You ahve to be willing to let me post up your dyno sheets and road test your car under various conditions.
The things I can adjust with the flash machine are:
Fuel curve
Ignition curve
Remove boost cut
Adjust rev limit
Boost level
Top speed limiter removal
IM me or email me if you are interested in beta testing
Fuel curve
Ignition curve
Remove boost cut
Adjust rev limit
Boost level
Originally posted by sir lurks alot
Can you get rid of test pipe cel's?
I will be a beta tester....i am about 20 minutes from pruven.
the only question that i have for you, is that I already have had my ecu reflashed from WORKS. Will you still be able to flash my computer. Currently I have a 3"TB with test pipe and buschur intake.
Works and we use the same reflash system all we would do is write over the off the shelf program with a new custom ma made on the dyno for your car.
I suggest you IM or M me your telehone number if you want to get in on the beta tests.
