Buschur Built 2.0L Shortblock w/ Oil Pan !!!
Buschur Racing 2.0L shortblock with 0 miles
You get the shortblock with the entire rotating assembly installed, Balanced, Torqued with the following...
Buschur Built 2.0L w/ Groden Rod
Bearings (Rod, Main and Thrust)
Balanced, turned & polished Crank shaft
Buschur Racing Balance Shaft Eliminator kit
ARP Fasteners w/ headstuds
BR Spec Groden Aluminum Rods
BR Spec JE Tough Skirt Coated Forged Pistons
FluidAMPR Built Motor Engine Dampener
Complete engine gasket kit
New headstuds and all brand new belts & tensioners
Kevlar Timing Belt & all new seals
New Oil pan, oil pump, water pump is included
Brand New Cam angle sensor & L19s
Compression Ratio: 9.0:1
Built by Buschur Racing supporting upto 1000HP
*Buschur Racing charges $1800 for core + additional $725 for good Crank as well*
NO CORE REQUIRED
Steal @ $4375 Picked up !!!
NO CORE REQUIRED
