Long Island 91 octane gas..
And before anyone starts flaming me for saying octane is a value and not an additive.. It is just the generic name of any group of additives used..
http://www.hyperdictionary.com/dictionary/octane
Not certain.. Its possible that other refineries will offer gas with higher octane for our region.. but for the time being, we'll be getting gas from the same refineries that Cali gets. And even that isn't 100% certain.. Its just not encouraging at the moment.
there is one sunoco in LI NY that is still selling 100,114 lead and 116 lead gas, exit 17 on the southern state express-way. many road worriors from the city travle far and wide to this station for the precious juice.
Yup.. Been to that one frequently recently.. 100 octane is the only Unleaded blend..
I got one better for ya, I live right near republic airport and the Air Power museum.. I fill up the Malibu on the Sunoco Piston plane fuel that they use.. Costs me a fortune so I don't do it frequently.
My point was that 100 octane is $4 a gallon.. Very expensive to fill up twice a week on plus its out of the way. I think that sunoco you're talking about sells Cam2 (if its the one in Nassau County) since I don't recall seeing any gas station selling the race or plane blends of sunoco.
Originally posted by MalibuJack
Yep.. It will still be available for some time until supply runs out.. But it will switch over at some point in the next month or two..
I thought I heard that Europe has much higher octane gasoline available at the pump?
Ya know.. I'm not really sure.. I know it probably will be all of New York.. Possibly Connecticut.. Not sure who else.
And FWIW, their eurpean/japanese octane rating is calculated differently.. 98RON is roughly equivelant to 94 octane here.. (I think, its more or less similar grades to what we have here though)
I thought some environmental groups say enthanol is actually more polluting. Certainly, if more fields are used to grow corn, its not good for wildlife, etc. I also thought I heard it does not yield as much power, but I could be wrong. One thing for sure, its a huge thing for farmers and is a pretty big give-away to the farm states.
I think your right about the amount of energy.. That is it takes more alcohol to produce the same output as gasoline.. The air fuel ratio is also different, which is why flex fuel vehicles are flex fuel (They adapt).. In a normally aspirated engine its a concern because your at themercy of the atmosphere controlling how much air-fuel you can get in, you can however raise compression significantly, since you need a bit more energy to vaporize alcohol, increasing compression would help generate the heat.
There are a few good things about ethanol.. the most obvious one is you can run higher compression (or higher boost) without detonation, unfortunately you have to do that to regain some of the lost power anyway.
I'm not so sure that alcohol is "polluting" When burned its byproducts are basically CO2 and Water.. Very few other pollutants come out (Obviously there can be other contributing factors that I'm unaware of)
Alcohol can be invisible when it burns, which can be very dangerous especially in a motor vehicle..
I'm personally a huge proponent of using alcohol, and I'd really like to see my car run on 100% alcohol if I knew it were possible (and it were easier to get at Ethanol or Methanol)
There's no question that you have to think a little differently when you decide to run an alternative fuel since tuning is a little different.
I don't know how bad it would be to grow products used to create alcohol products, You have vegetable waste and other things that can be used to make Ethanol, and wood product waste which can be used for Methanol. All of these things are renewable resources and over time, can be produced regionally and cheaply. A huge threat to the Oil companies which is why you are only beginning to see blends of gas with alcohol, even hybrid cars and alternative fuel cars progress is stymied by lobbying on behalf of the Oil industry.
Originally posted by mikesevo8
Doesn't this happen every winter ???
Most stations get the lower octanes because of the weather ...
I bet the 94 will be back in the spring...
http://terrasol.home.igc.org/alky/alky.htm
For anyone who's interested... Like I said, if I could "Fill up" on alcohol easily, I'd definitely consider it.
