Northwest Region Includes AK, ID, WY, SD, MT, ND, CO.
Alaska
Old Jul 10, 2011 | 01:16 PM
  #2761
akeric's Avatar
Originally Posted by QwikEVO
goddammit. ANOTHER Evo in Eagle River?
and that "meet" is a joke. Waste of time, IMO.
and how do you know your turbo is maxed out? There's plenty of Evos on this forum running 11's on a stock 8 turbo (even some in the 10's). I highly doubt you're at the limit of the stock turbo. If you feel that you need something more, go with a 10.5 hotside or find a 9 turbo. My 9 turbo still has more in the tank...I just need better track prep and a flawless launch to squeeze more. Or e85...but that'll never happen unless you pay out the *** for it.
the meet is a joke, but there are still some people out there that aren't total idiots, and its as close as I get to a meet I think. I don't do the 'cruises' and I don't go often, but it keeps me from going to the bars and getting in trouble. Plus it can be cheap entertainment.
Old Jul 10, 2011 | 03:15 PM
  #2762
steelfire19's Avatar
Im not 100% sure that its maxed i just assume, it surges between 14-16lbs at wot and then the boost really spikes at about 5k rpm, i was able to take a video yesterday of it so i will try and upload it, i have the 10.5 turbo but would like to get a IX sometime soon.
I finally saw your car on thursday night you were headed towards ER from anchorage around 830 or so, it looks sweet all blacked out but i was only able to check it out for that split second.
Old Jul 10, 2011 | 03:52 PM
  #2763
QwikEVO's Avatar
You should be at 18-19psi with it tapering off in the top end. Sounds like you either have a bad vacuum line connection with your boost controller or gauge, or you have a boost leak.
Thanks, I don't get it out as much as I should...but it was a beautiful day not to on Thursday. We really need to get on this meet planning business before the weather takes a ****.
Old Jul 10, 2011 | 04:43 PM
  #2764
I believe its set at 23 with a peak of 25 (thats what i was told by the guy who tuned it) which seems kind of high which is what could be causing the surging i am assuming, the last few times i have logged 3 Bar Map says 28.905 which i think is like 14-15psi but my failsafe is whats holding my boost down so low, now that i think i have that fixed i have yet to log and see what it says.
I work in ER, im there almost everyday except i leave for vaca this week so we should meet up, sometimes this car frustrated the hell outta me.
Old Jul 10, 2011 | 11:41 PM
  #2765
Buddlight's Avatar
Your 3 Bar MAP should read the same as your boost gauge, unless you didn't set the scaling for you elevation in EVOScan.
My buddy had the same surging on his 8, I did a boost leak test and found a huge leak at the LICP, and a ****ing hole in his FMIC. So yeah, do a boost leak test.
Old Jul 11, 2011 | 09:30 AM
  #2766
DNBishop's Avatar
[quote=QwikEVO;9449985]You should be at 18-19psi with it tapering off in the top end. Sounds like you either have a bad vacuum line connection with your boost controller or gauge, or you have a boost leak.
Do a boost leak check............... My 9 can carry 21 all the way to redline (4 bar OMNI). I would thin 8's could too (I may be wrong). I have the load boost tune/mod on it. Manual boost controller? Blow off valve? How is the boost controlled? Of course I am not an expert and still working out tuning gremlins.......
Buddy
Old Jul 11, 2011 | 09:36 AM
  #2767
1st- I use the grimmspeed 3 port solenoid and 2nd here is that video, now most of its junk but i didnt edit it yet, so the only part that matters is from 1:00-1:12 or so, you can hear boost kick in 3rd gear and then about the 1:08 mark is when it pulls out of 14psi and jumps to about 23 which i think is where the meth kicks in.
http://s1200.photobucket.com/albums/...0709171541.mp4
Old Jul 11, 2011 | 10:22 AM
  #2768
QwikEVO's Avatar
man, I really need to start getting back into playing around with my car and digging around on the forum.
Half the crap you guys are saying I am like WTF.
Old Jul 11, 2011 | 11:26 AM
  #2769
wrcRS's Avatar
Its all ECU controlled Boost chat.
I prefer the simple Hallman. Set it and forget it.
Old Jul 11, 2011 | 11:37 AM
  #2770
QwikEVO's Avatar
That's what I figured. I just have my little 'ol Greddy Profec B. Worked fine for me for 6 years...
Old Jul 11, 2011 | 11:57 AM
  #2771
anyone wanna make a buck, or a couple hundred and help put some cams in?
Old Jul 11, 2011 | 12:52 PM
  #2772
Buddlight's Avatar
OMNI 4 Bar for logging and Hallman MBC for me.
Couldn't help you with the cams, however my best advice is to get VRSpeed to give you a tune after you get them installed. I would recommend Mellon as well but I don't think he does ECU controlled boost via remote tuning. I've said it before, I wouldn't let any local shop touch my tune. Hell, even if you don't get the cams installed I would still get a retune from a real tuner with experience in ECU controlled boost.
Old Jul 11, 2011 | 04:12 PM
  #2773
dkstas's Avatar
Don't forget to let people know about the valve springs...some people are able to do it with a certain tool with the head still on but I wouldn't recommend it. How much are the local shops trying to charge for that?
Old Jul 11, 2011 | 05:04 PM
  #2774
QwikEVO's Avatar
what size cams are you running?
272s dont really need them. I never changed mine out.
Old Jul 11, 2011 | 05:08 PM
  #2775
Yea i have the gsc beehive springs, most hear that and want to tear the head off to do which is why they all want like 800+ for the install and then another 200-300 to tune the damn thing, i need a turbo put on as well so im trying to find someone who is handy at that and i would just love to help. Im not very mechanically inclined.
Best price in town is Nate at pie-r he quoted me 400
