Northwest Region Includes AK, ID, WY, SD, MT, ND, CO.
need Manual Boost contoller
Old Dec 6, 2005 | 07:03 PM
mikiblueeyes's Avatar
Does anyone has a Manual Boost controler?. I am troubleshooting mine for overboosting problem. So I need MBC ASAP. Please let me know if anyone in Portland area has one I would need it for a day or so.
Old Dec 7, 2005 | 05:44 PM
so noone has a MBC laying around for a day?
Old Dec 7, 2005 | 05:48 PM
haze1995's Avatar
I have a Turbo XS MBC that came with my UTEC laying around. However I am currently deployed and wont be home till the middle of January. I would help you out but you know? If you still need it when I get home, let me know.
Old Dec 7, 2005 | 06:07 PM
Zemo's Avatar
I have a hallman MBC, under my hood. If you only need it for a few hours, I could meet up with ya, toss it on your car, do your testing, and put it back on mine.....Of course, my car can't go anywhere without my MBC!
Old Dec 7, 2005 | 06:25 PM
Thanks Zemo, let me know when and where so I can test it out. PM sent
Old Dec 7, 2005 | 06:36 PM
en1gma19's Avatar
Well, you could, but you would only run wastegate pressure which is ~11-12psi.
Old Dec 7, 2005 | 07:52 PM
jj_008's Avatar
Not quite. Try 30 psi. It takes pressure to open the wastegate.
Old Dec 7, 2005 | 07:59 PM
I had it for a week without Boost controler boosts tops at 12 PSI. (Hose routed WG to Turbo Comp side)
Old Dec 7, 2005 | 08:36 PM
en1gma19's Avatar
Think so? Go disconnect your boost controller and go WOT and tell me what your peak is. What you said totally contradicts the entire purpose of a wastegate. It's there to prevent overboost LINK
*edit: This is how mine is currently set up as I am waiting to install a new boost solenoid since my old one is crapped out. With the vaccuum line from the wastegate/lowerIC pipe capped off, it will indeed only hit 12psi. I know from experience.
Old Dec 7, 2005 | 08:49 PM
Jim_Patterson's Avatar
I know that when you pull the wastegate line on a 16g you push 26-28psi.
Old Dec 7, 2005 | 09:55 PM
jj_008's Avatar
Yep .
Old Dec 7, 2005 | 11:08 PM
Hold on, can you explain how you pull the line to get 26-28 PSI boost. Cause I am overboosting and want to troubleshoot. let me know.
thansk
Old Dec 8, 2005 | 06:48 AM
jj_008's Avatar
thansk
If you are over boosting, then you have a boost controller issue. What boost controller are you using? Are you using the factory vacuum lines? If so, did you remove the restrictor pills in the lines?
Old Dec 8, 2005 | 08:53 AM
where are the pils located (I have 2 WGates 12 and 19 PSI) 12 works fine but 19 overboosts with boost controler. However it works without it just by pluging it directly.
Old Dec 8, 2005 | 09:01 AM
lexat20's Avatar
I have a AMS I'll send to you ups and its yours to keep
