Northwest Region Includes AK, ID, WY, SD, MT, ND, CO.
Evo Dyno'd @ Torque Freaks
Old Mar 3, 2007 | 11:21 AM
Paul Nelson's Avatar
It depends on temps
Old Mar 3, 2007 | 07:12 PM
Evogelion's Avatar
Is the failsafe worth it on the meth injection with a proper tune?
Also anyone know if dual port 10.5 hotside is better then single port? Also anyone know any sites selling these besides Gruppe-s (out of stock) and lancer shop (single only)?
Old Mar 3, 2007 | 08:47 PM
uglyevo's Avatar
www.forcedperformance.com
Old Mar 3, 2007 | 08:58 PM
nj1266's Avatar
The AFR on your car is scary lean. You are in the 14-13:1 range. May I suggest that you log your car on the street and find out what the Knock Sum is. All you need is a tactrix cable and a lap top.
With the cable you can download your flash and look at your timing. I really hope that the tuner really pulled the timing back to account for such lean AFR.
The good part is that your boost is set @ 20 psi only. Is this on 91 octane gas?
Old Mar 4, 2007 | 10:22 AM
Evogelion's Avatar
92 octane. I'm pretty confident in Jason's tuning abilities. Well when I get the knock sensor checked out I'm going back down there to get it reflashed again.
Old Mar 4, 2007 | 10:48 AM
Jim_Patterson's Avatar
Blue date is pre-tuned.
Old Mar 4, 2007 | 10:56 AM
There tail pipe probe is bad there getting a new probe real soon so the readings aren't right...
Old Mar 4, 2007 | 11:13 AM
Torquefreak1's Avatar
Jims right. The blue run was the base run when the car got strapped down.
Old Mar 4, 2007 | 12:00 PM
nj1266's Avatar
You are correct. I made a mistake. But why was the car running so lean before the tune?
Old Mar 4, 2007 | 12:32 PM
joseph143's Avatar
that pretty good numbers. Yesterday i put down the same with a 06 evo 9 with a vishnu flash. I can't wait to get back to chicago and run the car at sea lever. 4100 feet elevation is a killer. I am also having a bit of knock though. I logged 10 counts around 6000. ****ty el paso gas. gonna try a race fuel pull to see if it will clear up the knock and maybe squeeze a bit more power out of it. anyway congrats man.
Old Mar 4, 2007 | 07:27 PM
Sleeper2G's Avatar
damn Seph oyu are going all out, like I said before.. ALKY injection!!!
Old Mar 5, 2007 | 09:14 AM
Your not from the NW, nobody cares.
Old Mar 5, 2007 | 11:34 AM
SLO4DR's Avatar
I don't trust the O2 probe at Torquefreaks at all. I did 360whp last summer with a 20g-9-5 and 50/50 water/meth and the usual mods at 24 psi.. I thought it was kinda low hp, but they spent more time disconnecting my Xede because they refused to tune it, than they did actually tuning the car. My car also obviously runs really rich even though on my dyno sheet it was tuned leaner than the poster's car is.
I dunno I hope to get an AEM this summer with my own wideband so I can have Rrev tune the car properly for once.
Oh btw I have my old '05 turbo with the 10.5 hotside sitting around gathering dust if anyone wants it. I think it has about 8k on it.
Old Mar 5, 2007 | 12:43 PM
Evogelion's Avatar
I try mike I do try..
PM'd
