Northwest Region Includes AK, ID, WY, SD, MT, ND, CO.
429whp stock turbo E85
Old May 3, 2007 | 07:27 PM
Lucas English's Avatar
Well could not be happer with the car.
So last week we did a 10.5 hot side and ebay O2 housing. (Crappy Ebay one which took about 5k worth of shop tools to make right for my car) So buy the good one like Al says.
Here is my thread on the 401whp with the stock O2 and 9.8 hot side.
https://www.evolutionm.net/forums/sh...light=E85+dyno
So cars mods list to date.
Quick list of mods.
-'04 SSL EVO IIIV Stock trubo
-HKS 272's
-ETS IC and piping with ETS intake pipe
-FIC 850s's
-Forge BOV
-10.5 Hot side
-Ebay O2 (needed tig welder, grinder and resurface to make right)
-255hp
-Cust cold air intake with airmeter in fender.
-E85 fuel
-spike 28psi hold 24psi to redline.
-Flash tuning done buy me.
-FP upgraded WG actuater (did no know my car had this mod last time was there when I bought it)
Mods since last dyno
-Cold air intake which let my hold 2psi more to redline
-10.5 hot side
-O2 housing
-ARP rod bolts
-BS remove
-stock head bolts
I have found if I start my pull to low on the dyno it likes to pick up knock so that is why I started my pulls at about 3500rpm. On my last pull starting my pull at about 3600rpm got me a bit better boost spike which is why the TQ was a bit higher.
28psi spike holding 24psi out the top.
Specal Thanks to.
Torque Freaks for a good deal on Dyno time
Paul for spraying my IC down with water
Old May 3, 2007 | 07:29 PM
Also my AFRS on the AEM wb are high 11s going to low 11s out the top. The dyno WB is a bit leaner.
Old May 3, 2007 | 07:30 PM
Bioxide02's Avatar
Nice!
Old May 3, 2007 | 07:33 PM
Jim_Patterson's Avatar
Damn Lucas, I didnt think it had much more left in it, definatly not 30whp. You have that sneaky pete bottle under the dash?
Nvr2old32's Avatar
Great numbers! I'd make sure since you had the knock issue on the dyno not to forget about that when your out on the road. Can't you just tune the knock out so you don't have to worry about it down low?
Mike
Old May 3, 2007 | 07:34 PM
Bioxide02's Avatar
Just curious... any dyno numbers on just normal pump gas?
Old May 3, 2007 | 07:36 PM
andyktlee's Avatar
Pocket Mo
Damn Lucas good work! I'm loving that moonshine more and more.
Old May 3, 2007 | 07:37 PM
clamps's Avatar
Wow, thats awesome!!! 429hp
Old May 3, 2007 | 07:41 PM
Well the dyno is over 4k worth of roller weight so the knock is never there on the street. Also the knock is not allways there on the dyno. I can be at 3-4deg and get 10cts or at -4deg and get 10cts like its PK knock. Last time I was on the dyno I spent time trying to get ride of it but just just lost TQ and never got rid of it. My car has no BS shafts so that could be a reson why it pickes it up easyer.
Old May 3, 2007 | 07:42 PM
Paul Nelson's Avatar
Congratz !!! Should make for a fun weekend at the track
Old May 3, 2007 | 07:45 PM
mikiblueeyes's Avatar
damn, nice numbers. Let me know if there is a space for extra car on the dyno, i need to see what my new tune puts out.
Whats a gas milage you get?
Old May 3, 2007 | 08:04 PM
Well if you are ripping on it alot you can burn up a tank in a 100mi. On my car I turned off the O2 and heve set the cruse at about 16.0 AFR and got 23mpg on the hwy with some ripping on it.
With the right tuner and avg driving I bet you could ave 20mpg.
Old May 3, 2007 | 08:27 PM
TFJasonO's Avatar
I wish I was there to see it !!! Sweet number's man where did you dyno at?
Old May 3, 2007 | 08:34 PM
clarkkent06's Avatar
Nice numbers!
Sorry man forgot the Love in the excitment.
Torque Freaks
