Northwest Region Includes AK, ID, WY, SD, MT, ND, CO.
help please
Old Mar 5, 2009 | 08:14 AM
gotem23's Avatar
help please
hey guys i having a little problem but when i am in a complete stop anywhere... and i start driving off in first gear... i am hearing a clunking sound. i believe its coming from the driver side... and i dunno wats going on .. its been doing this for awhile. any one know wats the problem?? thanks guys
Old Mar 5, 2009 | 08:23 AM
Caesar's Avatar
Do you have an aftermarket downpipe?
Old Mar 5, 2009 | 08:30 AM
smokedmustang's Avatar
Downpipe? Or worn carrier bearing? need more info!!!
Are you running over the curb? Neighbors pets? Is there a passenger in the car that keeps hitting her head on the window when you take off?
Old Mar 5, 2009 | 08:44 AM
gotem23's Avatar
i have an aftermarket downpipe... and i dunno if it a worn carrier bearing i havent checked it were would that be located at?
Old Mar 5, 2009 | 08:45 AM
gotem23's Avatar
i have an a mxp downpipe
Old Mar 5, 2009 | 08:47 AM
Its the round rubber rings around the driveshaft underneath (Carrier Bearings). Go under the car and look at the downpipe. See if its rubbing around the oil pan. If its CLOSE to rubbing, it just may under acceleration as the motor moves. I wedged in a small piece of wood between the downpipe and the body, and tried to make it make the noise again, and it DIDN'T. Then I just adjusted the Downpipe so there was ample space. I bet thats what your issue is. Good luck.
Old Mar 5, 2009 | 08:50 AM
Curt@MrLed's Avatar
Former Vendor
You may have a big headed guy with a mullet trapped under you car. ^^^^
Or you should take it to someone who knows cars, will save you a ton of headaches cause your problem could any of 20 issues.
Old Mar 5, 2009 | 08:51 AM
Caesar's Avatar
Hmmm, when I put my APS 3" downpipe on I had a similar issue. There was a clunking noise coming from the drivers side wheel well. I had the tech from Auburn Mitsu check it out; I know, bad move but wasn't aware of their track record at the time. Anyway, he said my suspension was going, but when I had a good tech check it out they came to the conclusion that my downpipe was hitting my sway bar. To fix it, I took it to DriftOffice where I bought the pipe and Bill came up with an ingenious and cheap way to fix it. Not saying this is the case for you, but it could be.
gotem23's Avatar
alright i will check that out to see if thats it thanks alot haha at first i thought it was coming from my wheels
Old Mar 5, 2009 | 08:54 AM
gotem23's Avatar
yah thats wat i was thinking that way as well i thought it might be from the driver side wheel well but anyways ill check the down pipe if thats not it ill take it to a tech. know any good places to go too?
Old Mar 5, 2009 | 09:22 AM
Caesar's Avatar
^ Where do u live? I've always taken mine to DriftOffice in Auburn, but if you're in Seattle then check out BelKirk and let'em know you're off EvoM.
Old Mar 5, 2009 | 09:26 AM
gotem23's Avatar
ok will do thanks caesar
Old Mar 5, 2009 | 09:30 AM
Caesar's Avatar
Forgot to mention, BelKirk is in Kirkland.
Old Mar 5, 2009 | 09:34 AM
gotem23's Avatar
is it the belkirk mustang?
Old Mar 5, 2009 | 09:39 AM
Caesar's Avatar
^ No, this is them:
http://www.belkirkbodyshop.com/default.htm
