Northwest Region Includes AK, ID, WY, SD, MT, ND, CO.
Help!! Please
Old Jul 26, 2009 | 04:34 PM
03EVOGUY's Avatar
Originally Posted by Chabada15
this is as good as having a K&N Typhoon intake system, both these parts just dont agree with evos,
and im TELLING you, if your car was flashed via ECUFlash, like it almost definitely was, then your flash is still there but your tune is in need of adjustment, have you added anything to the car since the tune was put in?
Yes, i have added a test pipe and the recirc kit for the BOV...but with both of these it ran fine.
Old Jul 26, 2009 | 06:09 PM
Chabada15's Avatar
yea but if its tuned for a VTA BOV and a cat, and now you have it recircing and theres a test pipe then you need a retune...plain n simple, stock injectors?
Old Jul 26, 2009 | 07:15 PM
JohnBradley's Avatar
You are getting unmetered air it sounds like. Look for loose couplers, torn hoses, loose lines. Evos cannot forget the tune, something hardware related has happened.
Old Jul 27, 2009 | 03:03 PM
03EVOGUY's Avatar
ive checked for leaks and didnt find any.... it ran perfect prior to me taking the cable off the battery.
Old Jul 27, 2009 | 04:52 PM
momo_EVO8's Avatar
boost leak tester, search in the "how to section" make one just to be safe its like $5 and worth it to have anyway. some leaks are easily over looked with an eye, air will find it.
No harm in checking even if your car was running fine before
Old Aug 1, 2009 | 10:54 PM
03EVOGUY's Avatar
idle is all fixed!! thanks to English Racing
Old Aug 2, 2009 | 09:25 AM
aeroweenie's Avatar
So, what was the problem?
Old Aug 2, 2009 | 03:57 PM
03EVOGUY's Avatar
the last tune was corrupted some how.
4b11slayer
Oct 18, 2016 09:36 AM
antreas1991
Jan 2, 2015 02:25 PM
06stiman
Aug 5, 2007 07:32 PM
Justindc2
Automotosports - Illinois
Oct 17, 2006 03:07 PM
