Northwest Region Includes AK, ID, WY, SD, MT, ND, CO.
coolant leak
Old Dec 29, 2009 | 06:57 PM
BlueEvoG's Avatar
coolant leak
Hey i was just driving today and i stepped on it for a few seconds and smoke started coming out from under my hood and i had a liquid spray onto my window, it smelled like maple syrup. So i know that is the coolant, but i just wanted to hear if many others have this happen, and what might have this happen i checked the lines when i shut my engine off and there seemed to be no leaks.
Old Dec 29, 2009 | 07:00 PM
buchnerj's Avatar
Any coolant in the overflow? Check the radiator? Could be the headgasket. I have read quite a few threads on here recently about incidents like this and a few pointed to a headgasket going out on them. Do a leakdown test and a compression test and see what happens. Check the radiator for any oil blowing into the coolant system. Do you have any white smoke at a cold start up? How much coolant are we talking about here?
Hope everything works out for you
Old Dec 29, 2009 | 07:07 PM
BlueEvoG's Avatar
**** that would suck if it was a headgasket, how much would you estimate it to cost if it was? It was a pretty good amount of leaking. o and yes i do have white smoke when i start the car out of the exhaust.
Old Dec 29, 2009 | 10:53 PM
jnut24's Avatar
do a pressure test and check your oil level!
DFelton
Aug 8, 2012 08:00 AM
LAN_EVO
Feb 23, 2012 05:22 PM
Dr..Evo
Sep 22, 2009 03:53 PM
Johnboy1065
12
Jan 28, 2008 01:38 PM
EvilDylan
Oct 13, 2005 09:50 AM
