Clutch went kaput :-(
You sure there's no fluid pressure, vs something else happening between the slave cylinder and clutch fork? If the slave cylinder went bad and there's no fluid pressure, that would be a pretty easy fix. Just have to take off the intake and UICP pretty much. Hope it's not worse!
^ Im with him on this, are you sure your slave or master cylinder didn't crap on ya? Does your pedal stay to the floor? More details of what happen.
Pressure from the pedal is from slave and master cylinder. If your line popped then you'll need to upgrade to ss and possible replace the slave or master cylinders.
Hope it's an easy fix.
Positive it's the TOB. Clutch fluid leaks straight out the bottom of the trans when I fill it and pump the pedal. Either the line inside the trans is leaking, or the o-rings on the TOB are shot.
