Northwest Region Includes AK, ID, WY, SD, MT, ND, CO.
Boost leak test?
Old Sep 6, 2011 | 11:35 AM
Sassaphrass's Avatar
Boost leak test?
Does anyone know of a place in seattle or north that can do a boost leak test (up to 30lbs) for a decent price? Or if anyone has any ideas of what my problem might be let me know.
Problem: I was tuned for 28 lbs of boost and for the last month or so the car will not boost over 21 lbs, iv'e tried a new boost gauge and a new boost controller. Thanks all
Old Sep 6, 2011 | 11:56 AM
jcl's Avatar
jcl
You can build your own pretty easily. I cant google it right not but if you search for a home made boost leak tester it should come up with a decent build. About the only big thing you would need would be a compressor capable of 30 PSI. Costs less than 25 bucks or so to make.
Old Sep 6, 2011 | 12:27 PM
M8NSTER's Avatar
Like we were just talking about, Tyler. Might be the wastegate.
I finally got my computer to stop being an a$$ and let me onto MAP's site (F U Pandora: )
http://www.maperformance.com/forge-a...or-evo-ix.html
Old Sep 6, 2011 | 02:23 PM
jdmEviL8's Avatar
^ i told Tyler that i think it was his wastegate too... but he is convincing me that the mbc is before the wastegate and supposed to let it open at around 30 PSI...
We troubleshooted 2 separate Perrin MBC with the same result
Old Sep 6, 2011 | 02:24 PM
yahu's Avatar
I made one once Tyler (not sure where I put it during a move). I should be able to make another. IIRC the hardest part was to find the PVC and coupler that was a good enough size to mount onto the turbo'd system.
Old Sep 6, 2011 | 04:04 PM
F0RSAKEN's Avatar
If two separate boost controllers end with the same result, I'd check wastegate too. If there are no severe leaks and the wastegate appears to be ok, I'd bet it's a dying turbo. 30 psi is way out of it's efficiency range.
Old Sep 6, 2011 | 07:03 PM
So the problem is probably the 4" crack in my exhaust mani. The tune im on from ER has my boost set at 28psi
Old Sep 6, 2011 | 07:09 PM
jdmEviL8's Avatar
LOL we were just talking about how your manifold held up so nice!! crap, sorry to hear maing...
did u keep your OEM manifold or u gonna get the Megan fixed?
Old Sep 6, 2011 | 08:13 PM
i gave Mo my stocker but im grabbing it back from him tomorrow, will probably just get the stock ported so if anyone knows of someone or a shop that ports mani's and does a good job for cheap lemme know
Old Sep 6, 2011 | 10:25 PM
ryancb's Avatar
http://www.siliconeintakes.com/index...32d24b2fe90ac7 Might be easier then trying to find the parts. At least IMO
Old Sep 7, 2011 | 07:34 AM
M8NSTER's Avatar
^That's a neat site! Tho that's not the OP's issue.
Tyler, call Andrew and see if he'll trade you (with some cash on top) for his ported stock mani. I saw a tubular mani at his house that I'm pretty sure he's putting on soon. If not, ask if he'll port yours for a few $. He did a good job porting mine!
Old Sep 7, 2011 | 08:36 AM
I gave him a call last night but he musta been at work or something. ill try again later today. Thanks again for the help
Old Sep 7, 2011 | 11:01 PM
D Grade's Avatar
Replace the manifold and let us know what happens.
Old Sep 8, 2011 | 08:29 PM
So we put the stock manifold back on the car, and now the car will not boost over 18psi(which is wastegate pressure i believe) and it takes until 5k to hit full boost with a stock turbo. Any new ideas? or is it probably the wastegate?
Old Sep 8, 2011 | 08:57 PM
D Grade's Avatar
Id bet WG. I believe I still have my stock IX WG if you need one.
