FS used camber plates
Just pulled these off tonight. They came with my Ohlins I bought last season, I believe they are Tein, but I really can't confirm. Either way they are quality pieces, and have seen 3 season of autocross with no issues.
I clean them up the best I could, so what you see is what you get, they are not show pieces. The inside arc of one plate is chewed up a bit from the previous owner, probably from wedging a screw driver to shift the camber back, the only other know issue is one of the 8 possible bolt holes is starting to strip out on one of the plates. The i.d. of the bearing is 18mm, and the caster is fixed.
With that said I think $125 shipped obo is reasonable, as these tend to go for 150 shipped. Thanks for looking
My understanding is they should work with pretty much any coil over. They have the small spacers for each side, and one set of top nuts. I bought a new set of plates that also have adjustable castor, they were simple a r and r procedure. I reused my top nuts, and threw the new ones in this kit. Worse case you have to buy a different set of top nuts ~$10 from Ciro Racing.
