Wider tires?
Old Feb 16, 2013 | 02:02 AM
fluxcapacitor's Avatar
Wider tires?
i have to get new tires and i was thinking going a bit wider than stock. I know our stock are 225/55/18 and i was thinking of getting 235/55/18. will this be safe? im not too familiar with tires/wheels setups.
Old Feb 16, 2013 | 05:55 AM
mRVRsport's Avatar
From: Out towards the countryside of Dallas, TX (USA)
If you use the stock rims.. the new size tire (sidewalls) will bulge out a bit, but you will achieve that wide(r) wheel look.
As long as you keep the same diameter tire, the OBC will still keep accurate speed readings and more importantly it'll still be able to properly control DSC.
Old Feb 16, 2013 | 09:25 AM
Alright cool thanks a lot, just wasn't sure if it was unsafe to have a bit wider tire on the wheel or not. I don't wanna make a turn and the tire just flies off the wheels lol
Old Feb 16, 2013 | 05:00 PM
mRVRsport's Avatar
ONLY if you happen to Also hit a speed bump or street curb, then you should expect that rubber to go flying...
Old Feb 28, 2013 | 08:49 AM
TEXAS TRAVISTY's Avatar
do yall know off hand what width the 18" OEM wheels are. I was woundering if the 225/55/18stock tires will fit on a set or 18"x9" wheels. any ideas?
Old Feb 28, 2013 | 07:30 PM
evoXskankz's Avatar
I sold some ssr type f that were 18x9 to a guy with a Honda civic si he put some 225 or 215 but it looked stretch. so i guess its possible to fit :P
Old Mar 1, 2013 | 05:27 AM
yeah i found out that sinse the tire is 55 tall the stretch will not be that aggressive i checked it out online had pics on a website of 225/45/18 stretched on a 9" tire. the 55 will give more room for the side walls for an easier stretch!
thanks!
Posted from Evolutionm.net App for Android
netjoy
14
Nov 8, 2012 04:38 PM
88888
Jan 29, 2012 01:39 PM
cloud64
Feb 15, 2011 11:45 AM
Brokenevo
11
Mar 1, 2010 05:54 PM
mines hotter
10
Aug 1, 2009 01:16 PM
