Just saw this online -
http://www.topspeed.com/cars/car-news/new-product-review-3m-paint-defenderclear-spray-on-film-ar154393.html
Quote:
How do you protect your supercar’s paintwork from stone chips? Two possible
answers: Either never, ever drive it, or pay thousands to have clear films
mounted to protect the trouble spots: nose, hood, rockers and wheel wells. An
exciting new product called 3M Paint Defender offers all the benefits of
permanent shields in an easy-to-use, crystal-clear spray-on film.
3M
invited some auto journalists up to their Minnesota headquarters last week to
unveil their latest innovation: a spray-on Paint Defender film that’s perfect
for DIY car guys.
Keeping a supercar showroom fresh is a constant
struggle, and the exterior paintwork is the hardest piece of the puzzle, right
behind the engine and electronics. Buyers will walk right past a supercar with
purring mechanicals if it has bad paint. Any visible paint scars from stone
chips can be a deal-breaker and can easily knock 15 percent off the car’s total
value.
Bad on a $10,000 Toyota but utterly devastating on a $200,000
Carrera GT.
Making things worse, low-slung supercars pick up more road
scars and any other type of vehicle.
Fixing stone chips in exotic cars is just not a feasible or cost-effective DIY project. Even most body shops aren’t equipped to fix the complex alloy and carbon panels, let alone drape on the 30-plus coats of baked paint needed for a quality touch-up or re-spray.
Until recently, the only defenses against stone chips were professionally-applied clear films that we’ve come to see on many Porsches, including the rear wheel flare of the 911.
Even among the tech guys at leading OEM supplier, 3M, these films are notoriously tricky to apply. It’s a three-man job involving lots of pre-cleaning, soapy water sloshes as the film’s sticky back is peeled, and a troublesome dash to get the films aligned and fit correctly before they set permanently. If not impossible, it was extremely difficult for a DIY guy to do the job alone.
3M
for DIY car guys.
value.
Carrera GT.
Quote:
There must be a better way! With 3M’s clear, spray-on Paint Defender film, at last there is.
Paint Defender dries to a super-glossy and deep sheen that perfectly matches OEM clear coats. The only visible evidence that the car has been sprayed is the masked line. For a line-free application, simply plan ahead and do the whole panel, like the hood for example.
The Good
Stunning results, it dries a smooth glossy clear
The glossy finish is safe for all future cleanings and polishes
The Bad
Needs to be re-done every few years for the clearest and best results
Function
3M Paint Defender is going to become a huge product for DIY guys and detailing professionals because it delivers results, is a fast job and costs pennies compared with professionally-applied, permanent guard films.
The Good
Easy to apply and relatively odorless (still use a mask and gloves)
Is easy to peel off – just make sure you get the kit’s pre-wax
The Bad
The best place to apply this product is inside a garage or shop to avoid any dust or bugs getting stuck while it dries.
Pricing, Compatibility and Availability
3M Paint Defender comes in individual cans that cost around $25 each. One can is estimated to cover half a hood. In addition to buying a few cans, DIY guys should be sure to get:
Application kit: includes pre-wax packet, a clear tarp to cover the rest of the car, and the exact type of 3M masking tape needed to have a perfectly smooth application line.
Spray-can trigger: highly recommended if you’re doing multiple areas. Finger fatigue is real.
The genius of 3M Paint Defender spray is that it’s totally compatible with all factory paint finishes. By drying crystal clear and extremely smoothly, the effect is high-gloss sheen, just like a new car’s clear coat.
Paint Defender is available now on Amazon and launches this weekend (May 3, 2013) at AutoZone before a global roll-out later this summer.
Target Buyer
The target consumer is a DIY mechanic with a garage and some experience masking areas for paint. Actually applying to product is a piece of cake: three deep, slow layers in a crosshatch pattern over one spray session. Focus on getting the right layered thickness in segments: do the left half of the hood first, for example.
Conclusion
All cars are susceptible to stone chips damaging their paintwork, even the latest Nissan and Infiniti models, like the 370Z Black Edition with self-healing paint.
3M Paint Defender is a slam-dunk solution to a universal supercar problem: stone chips. The lower, rarer and more expensive your car, the more you should look into 3M Paint Defender spray-on film.
Something I would definitely consider.. Especially since I was already thinking about PlastiDip-ping the lower portion of our O.Sport, why not just use this stuff instead.There must be a better way! With 3M’s clear, spray-on Paint Defender film, at last there is.
The Good
The Bad
Function
The Good
The Bad
Target Buyer
Conclusion
This is not bad. I think you need an extra paint defender spray to cover just the hood. Found them in Amazon the whole kit with only 1 can of defender spray.
Well, I was thinking of using this to protect our doors from nicks & scratches by careless people in parking lots.
And, for $25 per can I'd pay that just for the ease of use!
(If you ever handled vinyl wrap, you'll know it's a lot cheaper and simpler too > Especially if you need to go around weird/complex contours and such.)
I bought a can of this from amazon and it arrived Thursday. It claims to protect almost as well as the film but only for 1 year. Either way, they wanted $300+ to do my front bumper, so it will take over 12 years before the spray was a poor financial choice. I'm applying it after finals are over.
Looks interesting, but went with the clear bra that protects the entire front bumper, partially the hood, partially the fenders, and both mirrors. So far so good!
