Service engine soon light - p0300 code
Old Jun 13, 2016 | 04:35 PM
cognizio's Avatar
Today as I was backing out of my driveway in my 11 OS the SES light came on, took it to auto parts store to get code read, came back as multiple misfire (p0300).
Anyone know what might be causing this? I have a 11 manual OS with 55k miles.
Old Jun 13, 2016 | 10:55 PM
mRVRsport's Avatar
From: Out towards the countryside of Dallas, TX (USA)
Some culprits (from simple to expensive):
1. Bad gas - Too much ethanol which could cause moisture in the fuel.
2. Bad spark plug(s) [or the coils that fires off the plugs]
3. A rip in the intake tube/snorkel
4. Malfunctioning/Failed MAF sensor. (it could just be dirty, so you get CRC MAF Cleaner and clean out the sensor, just be extra careful when spraying!)
These are just a few off the top of my head.
There obviously could be other more involved causes/failures.
If you haven't done any basic maintenance, I'd say start there and get those done. IE: change spark plugs, air filter, oil/filter change, etc.
Keep us posted.
Good luck.
Old Jun 29, 2016 | 01:21 PM
cognizio's Avatar
I thought sparks maybe, but code went away and hasn't come back since, I'll be swapping out plugs next week since I'm at 55k miles.
I know on the evo this used to happen often when over throttled.
Old May 28, 2024 | 06:38 PM
GeminiEvo's Avatar
Do you have the "Freeze Frame" data for this code? I get this code from time to time. My X is much more modded and tuned on e85. If the e85 changes slightly it'll set this code off because my LTFT is maxed.
Hotsht94
13
Dec 24, 2012 11:29 AM
Darewood
Mar 29, 2011 05:28 AM
mmolch2
Feb 12, 2010 09:18 AM
Wayne99gsr
Northwest Region
32
Dec 10, 2008 06:05 PM
forum04pl
Aug 14, 2005 01:18 PM
