Aftermarket wheel offset inquiry
Old Jul 2, 2020 | 06:37 PM
gn02156668's Avatar
5 Year Member
Hello all ,
Does anyone know if the following aftermarket wheel - Sparco Terra 16 x 7 (offset 35mm) will fit the 2016 Outlander Sport ?
I understand that the OEM wheel offset is 38mm and I am currently running on a set of Sparco Drift - 16 x 7 (offset 45mm) with BFGoodrich KO2 tyres
So with the 35mm offset , the new wheel will be 3mm closer to the fender comparing to the OEM offset 38mm , is that correct ?
Thanks all !
Old Jul 7, 2020 | 03:10 AM
SicLanEvo's Avatar
That should be correct! I cant wait to check out the setup. Post up some pics once its done
Old Jul 9, 2020 | 05:46 PM
gn02156668's Avatar
5 Year Member
Thank you for your reply !
Old Nov 17, 2020 | 12:30 AM
xelloss's Avatar
I'm running 17x7.5 35mm FAST Switch wheel, they fit perfectly. They are wrapped with Falken Wildpeak A/T Trail, tire size 235/60/17. A little tire poke and look aggressive but no rubbing at all.
16x7 35mm offset should be just fine, but I doubt that you can find a tire size similar to stock...
I was looking at 16 inches rims at first but found that all tire sizes are 4% bigger than stock.. that's too big.
travail
Jun 11, 2010 12:23 PM
riksride
May 12, 2007 02:07 PM
mchuang
Dec 1, 2006 07:25 PM
