PDT Alky Kit
PDT Alky Kit
I was wondering how your Alky kits compaired to those of SMC and Buschur? Do they work the same? Are they progressive or just switch on? Do they come with warning lights and test buttons and so on?
Thanks Guys.
Thanks Guys.
I can not speak for the SMC or the Buschur kit as it is not my place, nor do I know everything about those particular kits. As for our own kit, is it more of a budget kit then anything else. Our kit is a modified version of the Coolingmist, it is centered around their pump most importantly, which is a 150psi rated pump. There is no controller with this kit because it costs about $200 extra. It is a completely mechanical setup which is used with a check valve. The alcohol is injected at 10psi and is not a progressive system. We also use a modified injector setup that provides a spray that will allow the alcohol to atomize in the most beneficial way. Like I said before, our kit is a budget setup that costs only $350. It is cost effective and provides everything needed to perform like every other alcohol kit on the market.
-Nick
Precision Dyno Tuning
-Nick
