Originally Posted by Ladogaboy
(Post 7326198)
Well, if you haven't had your car tuned for an intake, I don't see how putting the stock airbox on would make the car run too rich. I wouldn't think that it would be any richer than stock. :confused:
I have a question. If the UR intake was making the car run lean, isn't the O2 sensor supposed to compensate?
Originally Posted by ReaperSevero
(Post 7326780)
What about Injen's CAI. Has anyone bought it and taken it to then Dyno and check if it runs lean or not. It is supposed to be tuned from factory. Has anyone check this out?
Originally Posted by MasterAK
(Post 7327451)
ok i havent been keeping up with this thread or any for a long time but, to my understanding, this issue is with the UR intake right? i had my car tuned by TTP and i wasnt told about this problem...why would he have this issue with that RA and not with mine??
cant wait for my email flash to come in.. just ordered it plus open port 2.0 cable
Originally Posted by JONralli09
(Post 7328082)
i have the UR intake and it was tuned by AMS and I didn't have any problems with it also.
Originally Posted by JaxRRevoX
(Post 7328020)
injen's intake is not a CAI......
Originally Posted by jaxrrevox
(Post 7328432)
good question, maybe ttp can chime in......
Does any K&N filter can mess up the AFR?Only drop in filter.
Originally Posted by gOOmba756
(Post 7330099)
(Post 7328020)
injen's intake is not a CAI.......
Has anyone maybe emailed Injen about there intake messing with the AFR? |
We have not dynotested an INJEN intake for Ralliart at this time so we cannot comment on its impact on the AFR.
We can comment on the Evo X intake version which still runs very rich over 18psi. |
Originally Posted by TTP Engineering
(Post 7331821)
I tuned an Evo X with an Injen intake and logged the LTFT-cruise for 45 minutes and they maxxed out at +6%. Then I adjusted the latencies down and tuned the boost. As I tuned the boost with multiple WOT runs, the trims fell to 0.19% and stayed there. I saw the AFR getting slightly leaner as the LTFT fell. THEN I adjusted the AFR slightly. I did not have to lean out the fuel map much to get the consistent and steady WOT AFR of 11.5:1 and tapering to 11:1 by redline. If you are not adjusting the latencies to have a rock solid LTFT, then the AFR at WOT is going to change whenever the LTFT changes. BTW, the AEM intake makes the LTFT on an Evo X even more positive at +10.9-11.9%. On the Evo X making the LTFT-cruise rock solid is a must for getting a steady, consistent and repetitive AFR at WOT. |
Originally Posted by nj1266
(Post 7331894)
The Injen makes the AFR rich because the LTFT at cruise hits +6%.
