oh[U] sorry I meant evoscan...can I just edit with cable and evoscan? what does anyone recommend for what I am after just getting limiter cut which is set to 112 miles per hr here,raising turbo cut slighty af if not still set to 100 ron from japan or at least 98 ron as best Australia has also set octane rating abit higher...what would be best way to change these? just 1.3r or U cable and evonscan and I can edit these and set straight back in to stock ecu? or I need to re-ecuflash after changing those things?
Getting this error:
Error: Unable to load DLL 'op20pt32.DLL': The specified module could not be found. (Exception from HRESULT: 0x8007007E) Also giving me the ftd2xx.dll not found error when I made sure to put it in the windows system32 dir I'm using a 1.3DA cable so why is it giving me this error? |
Originally Posted by Grimgrak
(Post 10918749)
Getting this error:
Unfortunately my problem is now
Info: OpenPort Firmware v1.12.368 Info: Battery 13.245V Info: Initialize Vehicle ECU... Info: Initializing At 5 baud... Info: Timer: 2116.2263ms Info: Initialization Complete... Info: Waiting for INIT Response... Error: J2534 Read Error - 16 Info: Datalogger Ended. Searching resulting in https://www.evolutionm.net/forums/ec...rror-16-a.html |
hello everyone
i have a problem i can not log zeitronix data to evoscan using both serial cable and the OBD II in zeitronix datalogger i can see the AFR,boost,TPS and RPM working very good. also i read that zeitronix datalogger has to be close while datalogging on evoscan but still not working the com port in correct on evoscan i seleted the right wideband tick the data i want to datalog but still not getting any data any help please? |
Did you select the COM port in evoscan to match the zeitronix ?
yes it is selected properly
^ I am having the exact same problem.
Zeitronix software picks up the information fine but in evoscan, its all zeros. I have selected the right com port and wb unit from the list. I have also restarted the laptop with the usb-serial cable. I have used two different cables. All the same result. fyi, using latest version of both software. |
I am getting the "no response from vehicle ecu"
Anyone know how to fix this. Using a 1.3u cable Thanks |
Update:
Got it working, after changing baud rate to 62500. |
I have the same issue with AEM UEGO through a serial port. I have selected the right com port and everything. I am going to try the 62500 baud number change and see what happens.
Tried it, and it did not work!!! Arrhhhh, How can I get EVOSCAN to read my wideband again!!!!
Originally Posted by blackoutVIII
(Post 11002500)
was it ever working before?
click on WIDEBAND and click on open com port manager, and view the port, does it show up in there as it was installed successfully (no exclamation mark)? |
(Post 11003124)
Guys , Has anyone experience AYC failure ? below is my DTC log ...
Hope someone could explain what is the problem :) Diagnostic Codes:12 Val. Power Supply 0xC0 And 0x02 Unknown DTC 26 Speed Sensor 25 Deformed Tyre 24 Rear Left Sensor Open 23 Rear Right Sensor Open 22 Front Left Sensor Open 21 Front Right Sensor Open 0xC1 And 0x01 Unknown DTC 0xC1 And 0x02 Unknown DTC 0xC1 And 0x04 Unknown DTC 41 TPS Open 34 ST-1,2 Short 33 Fixed ST-N High 32 ST-N Short 31 ST Sensor Open 0xC2 And 0x01 Unknown DTC 65 ABS Monitor 0xC2 And 0x04 Unknown DTC 61 Stop Lamp Switch 0xC2 And 0x10 Unknown DTC 56 G Force Sensor (Lateral) 52 G Force Sensor (Stick) 51 G Force Sensor (Straight) 0xC3 And 0x01 Unknown DTC 83 Pump Fail 2 82 Pump Fail 1 81 Pump Relay 0xC3 And 0x10 Unknown DTC 73 Left Direct Valve 72 Right Direct Valve 71 Proportion. Valve |
