EvoScan v2.6 And New EvoScan GPS/Logger/Reflashing Touchscreen Review
No idea. There is no reference to the tables in any code. I sent an email to Colby hoping to get some CAN enlightenment from him. :-)
I am not sure if there is any area that i can be of use here since new to this software. I do have a mut3 scantool here if anyone has something specific for me to check. I have a evox and evoscan with the 2.0 cable. also may be able to check things with other can mitsubishis and a evo9. If i can be of any help just pm me. thanks
I tried to log with Evoscan 2.6 but when i start up the program AND try to start the logging process I get this error:
Error: Unable to load DLL 'op20pt32.DLL': The specified module could not be found. (Exception from HRESULT: 0x8007007E)
Info: Datalogger Ended.
When I open EvoScan 2.5 it opens correctly, I also have the lastest ECUFlash installed onto my computer and I've tried using another logging program which works fine. What's going on?
I have checked the program on two difference cars now, a JDM Mitsubishi Galant VR4 and a Mitsubishi Ralliart Colt. I downloaded the non EVO IX files, and it worked on both straight away, but I am only getting data rates of less than 50/sec
But at least it fully works so its a big starting point. This was with the openport 2.0 cable
After installing the newest version of ecuflash, I was able to log successfully with my Evo 9 with the O.P. 2.0 cable. The only thing that I couldn't get to work was the map tracer, does that have anything to do with having multithreading on/off?
'op20pt32.DLL' is related to your OP 2.0 cable drivers
That's what I thought initially so I uninstalled ECUFlash but I still am having the issue, I'm actually using Vista Home Premium 64bit. I'm also getting an error during start up for "FTD2xx.dll" not being found and when I try to initiate the logging process something else pops up again saying it can't find the same .dll file. I'm stumped...
Ok uninstall then reinstall. Go to the EVOSCAN 2.5 folder and (or whatever folder you are going to use), right click and make sure read only is not selected in any way (blank, no check mark or blue), apply all and close. Then copy over the beta files as directed. I had to do this to get everything to work in Vista.
It's strange because I tried what you said rogue and it still doesn't seem to work. I'm getting this error, not sure if its the same as some people but I've attached a few screen shots of each error I get.
I just tested it out on an EvoX. Not all parameters that were checked by default worked.
Battery level, tps, engine speed, fuel trim (LTFT), and O2 feedback (STFT) seemed to work fine.
Injector Pulse Width didn't seem to work (stayed at 0ms)
IGN timing advance (-20) & Air temp (156.2 F) showed strange numbers
seems good progress so far, thanks SIC for your excellent feedback, any ideas how to fix the functions, and request_id, let me know. try some of the other Y numbers (CANX-Y) 0-3
I tried the installation again with the beta 11 upgrade following the instructions to a T but I'm still getting the same errors as I posted earlier. Anyone know what's going on?
