Veeve, Please log a support call or email. this thread is about new and uupcoming features, thanks.
Quote:
Hamish,Originally Posted by evo4mad
I have sent 2 emails and 5 support calls since 20th of Feb, but didn't get a reply.
I'm sending a PM to you now.
EvoScan v2.6 beta9 is proving to work very well with both v1.05 and v1.04 firmware of the OpenPort2.0 cable. Take a look at this:
EvoScan v2.6 beta9 with SuperSpeed enabled, log to disk disabled, and Multithreading disabled:
GPS Navigator v1.3 software update is now available.
- Added: The Ecu reFlash read/write screen can now connect after dataogging, and it will cancel the datalogging if its still running.
- Added: ReFlash Evo9 Support - please let me know if this is working on Evo9 ecus.
- Added: Lap Timer EXAMPLE Only Screen.
- Added: 1/4 Mile EXAMPLE Only Screen.
- Added: Actuators is EXAMPLE Only Screen.
Hi Hamish,
As I understand, the device runs on WinCE. Can we add additional programs to it on our on ?
How is the EvoX support coming along? I remember hearing it was going to be tested this week but never heard anything after that.
Let me know if you need any more testers on the EvoX.
EvoX new datalogging values for beta10!!!! oh yeahh!! I'm sure I can come up with more too.
2008/09 EVOX EFI ECU:
Battery Voltage
Idle RPM
Vehicle Speed
Intake Sensor 44 deg c
Coolant Sensor 68 degC
MAP Sensor 102.4kpa
Airflow Sensor 1171.9 mV
APS Main 996.1 mV
TPS 722.7 mV
TPS max 4375.0mV
TPS(main) learn 859.4mV
TPS(sub) 4257.8mV
Ignition Advance 61CA
Injection Time 0.0ms
LTFT Bank1 -1.2%
STFT Bank1 0.0%
Knock Retard 0.0CA
Knock Learn 100%
VVT Intake 15.0CA
VVT Exhaust -25.0CA
Purge Relay Duty 0.0%
Throttle Actuator 6.7%
ETV Idle Open 0.7V (electronic throttle valve?)
ISC Learn (A/C off) 0.0 L/S
ISC Learn (A/C on) 0.0 L/S
Absolute Load 0.0 %
Accelerate Load 0.0%
Crank Signal Off
Airflow Sensor 0.40g/s
Front 02 Sensor 0.000V
Rear 02 Sensor 0.000V
APS 102 kPa
TPS relative 6.7%
TPS sub
APS Main 19.6%
APS Sub
Fuel Status 1 0L
RV
Read/Clear EFI Trouble Codes
2008/09 EVOX ABS ECU
Longitudinal G-Sensor 0.000G
Horizontal G-Sensor 0.022G
Yaw Rate sensor 0.0
Brake Level Switch NORMAL
Engine RPM 0.0 rpm
Engine Torque 0.0Nm
Expected Gear Value D N R
Current Gear Value R D
Brake Sensor OFF
Horizontal G-Sensor Offset Value -0.007G
CVI Oil Temp
Primary Gear Speed 4096 r_min
real engine torque
correct engine torque
input torque
gear position 1st
Read/Clear ABS Trouble Codes
Battery Voltage
Idle RPM
Vehicle Speed
MAP Sensor 102.4kpa
APS Main 996.1 mV
TPS 722.7 mV
TPS max 4375.0mV
TPS(sub) 4257.8mV
LTFT Bank1 -1.2%
STFT Bank1 0.0%
Knock Retard 0.0CA
Knock Learn 100%
VVT Intake 15.0CA
VVT Exhaust -25.0CA
Absolute Load 0.0 %
Crank Signal Off
APS 102 kPa
TPS relative 6.7%
TPS sub
APS Main 19.6%
APS Sub
Fuel Status 1 0L
RVRead/Clear EFI Trouble Codes
Yaw Rate sensor 0.0
Engine RPM 0.0 rpm
Engine Torque 0.0Nm
Brake Sensor OFF
CVI Oil Temp
real engine torque
input torque
gear position 1st
Quote:
OMG! I need to test it!!!Originally Posted by evo4mad
Hamish,
Can you post a copy of the Evo X Data.xml file or send me a copy? I've been unable to determine the RAM address for the accelerator pedal position. The MUT address for it in your Data.xml file will point me to the RAM address.
Hello HamishOriginally Posted by evo4mad
GPS Navigator v1.3 software update is now available.- Added: The Ecu reFlash read/write screen can now connect after dataogging, and it will cancel the datalogging if its still running.
reflashing/reading fro the Evo IX ECU is not working for me. There's always an error during the process
BR
mlocatel
yeah have you seen the screenshots? if you look closely you'll see the "desktop" option, you can run what you like.Originally Posted by silverstream
Hi Hamish,As I understand, the device runs on WinCE. Can we add additional programs to it on our on ?
There is a whole bunch of accelerator ones, do you want them all?Originally Posted by mrfred
Hamish,Can you post a copy of the Evo X Data.xml file or send me a copy? I've been unable to determine the RAM address for the accelerator pedal position. The MUT address for it in your Data.xml file will point me to the RAM address.
Quote:
PERFECT !! Ordering one soon !Originally Posted by evo4mad
