EvoScan v2.6 And New EvoScan GPS/Logger/Reflashing Touchscreen Review
Hamish,
I'm having a logging issue using the beta 7. Using windows XP with a tactrix cable, when I click to start the log, I get three messages reading:
"ComPort open"
"comport Read A 0"
"comport read C 0"
It will then try to re-connect, it throws the same three messages, then it cancels the action. Currently I am using a beta version of 2.6 that does work(not sure which one).
Thanks.
"ComPort open"
"comport Read A 0"
"comport read C 0"
Thanks.
The more I use evoscan the more impressed I am. Sure it's got it's issues but what piece of software doesn't. Keep up the great work Hamish!
i guess i should have asked this before i bought the item or maybe i missed the answer in this thread...
is there only ONE usb port? and if yes, how can i log my wideband and the ecu at the same time?
last I saw he was investigating a splitter on the usb or the power lead(?)
I am looking for a method to log my WB and MAP into the same log as all other EvoScan information.
https://www.evolutionm.net/forums/ec...-2j1-wbo2.html
Thanks GiGas
search for MrFred's thread...
Does your WB02 has a 5v analogue output?
if so just wire it upto rear 02 ADC input on the ECU (signal only, leave heater alone)
then u just gotta work out the scaling...
I will try to finde the tread of MrFred you refere to.
ok
can you tell the WB02 to output different volts for AFR's?
ie
0v = 10AFR
5v = 17AFR
linear in between?
that will make working out your evoscan scaling/formula much easier..
ie Eval=(17-10)*x/255+10
So when you have 5volts your formula will spit out 17AFR which is correct..
let me know if u need help with it
ie
0v = 10AFR
5v = 17AFR
linear in between?
When looking in the TE WB02 data scheed http://wbo2.com/2j/default.htm I found that
AFR = (V*2)+9
or
V=(AFR-9)/2
AFR = (V*2)+9
or
V=(AFR-9)/2
Ok then.
I will have to replace the signal wire from the second stock O2 sensor whit the 5v output signal from my WB device.
Make an change to EvoScan formula and then I should be don.
Will this give issues on the MIL ( error codes ) ?
As of today the second O2 sensor are just lifted out from the direct exhorst gas - and cause no MIL.
Best thing todo is:
1) leave rear 02 sensor in place and connected - for heater related CEL's
2) use tephramod 5.10 or above - for rear02 signal related CEL's
3) replace the signal wire of the rear02 with that of the wb02 so you can log wb02 via ECU
That makes sense
Thanks alot, I will look up the ECU pinout to finde the rear 02 ADC input on the ECU.
Try to finde the program mod you have made, and solve how to implement it to my ROM.
Next I will work out how to change the formula in EvoScan 2.6
Local time is 02:43 so I need to sleep before work :-(
Thanks GiGas
Thanks GiGas
