EvoScan v2.6 And New EvoScan GPS/Logger/Reflashing Touchscreen Review
Old Apr 12, 2009 | 10:03 AM
  #526
jmorris1027's Avatar
Why is this so difficult. Cant it be made retard proof? Where can I get these FTDI drivers that it says i don't have that i know i installed? I'm doing this exactly as you say but no matter what I get an error upon starting evoscan, then then i put 500000 in baudrate i get another error. then it says evoscan has stopped working epic fail you suck then closes. its getting really frustrating. why do you need to be a damn rocket scientist to figure this out. It says my data xml is damaged or out of date, among other errors it gives me.
Old Apr 12, 2009 | 11:04 AM
  #527
dolphin888's Avatar
Can somebody help me with baud rate setup?
The problem appears, when I wanna use beta11 with OP 2.0 cable. With OP 1.3 I can log quite fast, but when I choose OP 2.0 and 62500 baud rate my logging is very slow(pic attached):
As far as I understand, I need 3 things to setup:
1) mods in rom/xml files
Code:
 <scaling name="BAUDRATE" units="units" toexpr="500000/(x+1)" frexpr="500000/x-1" format="%.0d" min="0" max="500000" inc="1" storagetype="uint8" endian="big" />
<table name="BAUDRATE1_OBD" address="ce3d" type="1D" level="1" scaling="BAUDRATE" />
  <table name="BAUDRATE2_MUT" address="ce71" type="1D" level="1" scaling="BAUDRATE" />
  <table name="BAUDRATE3_unknown" address="ce81" type="1D" level="1" scaling="BAUDRATE" />
2) baud rate for OP 2.0 vable in device manager
57600 ???
3) Evoscan setup
OP 2.0 radio button + 62500 baud rate + superspeed logging
What can be wrong?
P.S. I'm using 90550001
Old Apr 12, 2009 | 11:20 AM
  #528
GST Motorsports's Avatar
Originally Posted by evo4mad
GST motorsports I gotta love your negativity:
"So where you even logging the above items last month?"
"kind of useless at this point"
EvoScan is always the best datalogging software for Mitsubishi, just happened that PCMScan fluked it by having generic CAN support, you just wait and see, EvoScan will surpase PCMScan by miles.
Yes please test it, link is above in POST#1, there have been no comments made by you about the accuracy on the current version and requests, so you are saying they work ok? that is a huge step forward if it even logs something, considering its the first version I've ever programmed CAN protocol. Can you compare it between PCMscan and tell me if the values are perfectly the same? If so, thats excellent, its a basis for extending it beyond the generic scantools, which EvoScan always does.
My apologies, I think it came over the internet wrong, I didn't mean to sound negative. I think sometimes my honesty is too honest.
I have no questions that EvoScan will be better than a generic logger, I've been a EvoScan user since your first beta version way way back when.
-Bryan
Old Apr 12, 2009 | 12:52 PM
  #529
mrfred's Avatar
Originally Posted by GST Motorsports
Tried logging with this today, kind of useless at this point unfortunately.
Tephra, MrFred, Gunzo, etc, I would love to see what you all think of this, and of course, if any testing needed, I would love to help as much as possible.
You've got an email.
Old Apr 12, 2009 | 04:20 PM
  #530
can anyone help me? anyone have any input? ive been messing with this all day and im about ready to throw the computer in the road. ill post screen shots in a minute.
Old Apr 12, 2009 | 06:09 PM
  #531
eag36's Avatar
I've successfully gotten it to log with the IX, but it is amazingly slow. Too slow to see anything from the log. I haven't upped the baud rate though, i'll try and see if that helps out.
Old Apr 12, 2009 | 08:48 PM
  #532
rogue's Avatar
I downloaded the Beta, I will test in the morning and get back... This will be for an EVO X.
Old Apr 12, 2009 | 09:08 PM
  #533
SiC's Avatar
SiC
I just tested it out on an EvoX. Not all parameters that were checked by default worked.
Battery level, tps, engine speed, fuel trim (LTFT), and O2 feedback (STFT) seemed to work fine.
Injector Pulse Width didn't seem to work (stayed at 0ms)
IGN timing advance (-20) & Air temp (156.2 F) showed strange numbers
Old Apr 13, 2009 | 09:23 AM
  #534
rogue's Avatar
Ok, can anyone help with this problem. I have a long file but I keep getting errors when I try to access it or load it. I even made another copy of the file and still came up with errors. Additionally, the sample log file will not load.
This is using the new beta.
Attached Thumbnails EvoScan v2.6 And New EvoScan GPS/Logger/Reflashing Touchscreen Review-evoscan_error.jpg
Old Apr 13, 2009 | 01:44 PM
  #535
mrfred's Avatar
Originally Posted by tephra
You might be better looking at the CAN registers/instructions in the ECU as a starting point for tracing the CAN stuff...
There was only 1 place that the ECU refers to the MUT_TABLE, so I don't think there will be a MUT->CAN or vice-versa translation.
Hamish - Where/how did you come up with your current list of CAN ids -> logging item?
After looking at things a bit more, I'm pretty sure that the tables I listed earlier are the CAN data logging tables. tephra, they should be in a similar location in your ROM (have you got your Evo 10 yet?).
Old Apr 13, 2009 | 04:30 PM
  #536
tephra's Avatar
rogue - reboot, looks like a previous process or excel has gotten your log file OPEN already... as per error message.
mrfred - not yet, fracking paper work going around in circles... maybe this week. I might look at your tables today...
Old Apr 13, 2009 | 04:43 PM
  #537
I was able to log some pulls last night and engine load seems to max out at 255, and when we tried to raise the limit, we couldnt reconnect to the car.
Old Apr 13, 2009 | 05:45 PM
  #538
tephra's Avatar
hrmm if its anything like CT9A then you will need to log calculated load until someone finds the 2byte stuff..
could be wrong thou
Old Apr 13, 2009 | 06:43 PM
  #539
mrfred's Avatar
could be wrong thou
There is a 1-byte load in the tables that I posted. Haven't looked to see if any of the other variables in the table are a 2-byte load.
What color?
Old Apr 13, 2009 | 07:17 PM
  #540
tephra's Avatar
any idea on how those 3 tables work together?
i am really just working in the dark here, hopefully I will be more useful when I have handson testing
