EvoScan v2.6 And New EvoScan GPS/Logger/Reflashing Touchscreen Review
Old Apr 14, 2009 | 11:03 AM
  #556
mrfred's Avatar
Originally Posted by evo4mad
ahaha, good, because Battery level, tps, engine speed, fuel trim (LTFT), and O2 feedback (STFT) are the only ones I worked on seems good progress so far, thanks SIC for your excellent feedback, any ideas how to fix the functions, and request_id, let me know. try some of the other Y numbers (CANX-Y) 0-3
Hamish, Can you see the RAM addresses of the parameters that you are calling, or is it only as you showed me in the PM?
Old Apr 14, 2009 | 12:31 PM
  #557
Red Dragon's Avatar
You guys should make a box that can connect to external gauges such as boost, wide band 02 sensor, oil temps, trans temp, egt, etc... and have the box connected to the Evoscan touch screen via USB port so you can view them on the screen.
Old Apr 14, 2009 | 07:40 PM
  #558
pltek's Avatar
anybody can email me link to v.2.5??
i was trying to download it from an email notification i got from Hammish when it came out but linky doesnt work
thanks in advance
Old Apr 14, 2009 | 07:44 PM
  #559
RAbishi's Avatar
Originally Posted by RAbishi
After installing the newest version of ecuflash, I was able to log successfully with my Evo 9 with the O.P. 2.0 cable. The only thing that I couldn't get to work was the map tracer, does that have anything to do with having multithreading on/off?
The maptracer wasn't working because I was logging 1byte load, has anyone gotten 1byte load to work with the maptracer?
Old Apr 14, 2009 | 07:46 PM
  #560
tephra's Avatar
workaround is to edit the XML and "rename" the 1byte load to the same name as the load that maptracer uses (of course remove the map tracer load)
know what i mean?
Old Apr 14, 2009 | 08:08 PM
  #561
RAbishi's Avatar
know what i mean?
Yep I think so, I will try it out. Thanks.
Old Apr 14, 2009 | 09:52 PM
  #562
evo4mad's Avatar
you can choose which load to use from the dropdownlist yeah?
Old Apr 14, 2009 | 11:40 PM
  #563
dolphin888's Avatar
Evo4mad, have you ever heard about lag, when logging with OP 2.0? Has anybody reported that?
Old Apr 15, 2009 | 06:18 AM
  #564
RAbishi's Avatar
Yes you can, and 1byte load even shows up in the drop down box but nothing displays in the maptracer when you only log 1byte load.
Old Apr 15, 2009 | 07:50 AM
  #565
mlocatel's Avatar
Hallo Hamish
are you working still on the SW for the GPS Unit?
Thanks
mlocatel
Old Apr 15, 2009 | 04:11 PM
  #566
mac214's Avatar
I am getting a access denied when attempting to open the link on the first page for the beta11 software. Any ideas?
Old Apr 16, 2009 | 11:52 AM
  #567
antons.bungis's Avatar
same here - Error: Access is Denied
can someone please mail it? ive got purchesed v2.5
myusername @ gmail.com
thanks a mill in advance
Old Apr 16, 2009 | 12:03 PM
  #568
rogue's Avatar
http://evox.fusionrace.com/EvoScanUPGRADEv2.6Beta11.zip
I will only keep it up until tonight. I cannot email any of these files because it contains an executable and I don't feel like encrypting.
Old Apr 18, 2009 | 12:34 AM
  #569
palmerblock's Avatar
can someone lead me in the right direction?
i am having these errors come up
Attached Thumbnails EvoScan v2.6 And New EvoScan GPS/Logger/Reflashing Touchscreen Review-evoscanvisa.bmp
Old Apr 18, 2009 | 06:20 AM
  #570
evo4mad's Avatar
access denied was a problem with my Web Hoster company, they have fixed their lame as server up.
