EvoScan v2.6 And New EvoScan GPS/Logger/Reflashing Touchscreen Review
Old Apr 10, 2009 | 07:23 PM
  #511
RAbishi's Avatar
Ordered! Thanks!
Old Apr 10, 2009 | 07:26 PM
  #512
FX11's Avatar
yussssssssss!
Old Apr 10, 2009 | 07:45 PM
  #513
demodeakin's Avatar
Is that Patch Connector ( https://www.evolutionm.net/forums/sa...g-evoscan.html ) Needed to Log with a AEM UEGO WB? I want to log a WB also so I can do some 3rd pulls to have Mellon write me some maps.
Deak
Old Apr 10, 2009 | 08:09 PM
  #514
binky's Avatar
Deak
A connection to the wideband is needed to log the values, yes. Do you have to buy his? No.
You can build your own. You just need an RS-232 (serial cable) and cut the cable and attach the blue wire (from the UEGO) to pin 2 (on the serial cable) and ground pin 5. Just make sure you use a continuity tester (on a volt meter) on the serial cable to make sure you have the correct wires selected (for pin 2 and pin 5).
You could also go to Radioshack and get a RS-232 connector and solder the wires on (instead of cutting a whole serial cable up).
-Bink
Old Apr 10, 2009 | 09:06 PM
  #515
RREvoX08's Avatar
From: Tallahassee, but currently reside @ Camp LeJeune
how do i unzip the file to use with the 2.5 i currently have?
Old Apr 10, 2009 | 11:35 PM
  #516
GST Motorsports's Avatar
I'm confused, you posted this last month:
Originally Posted by evo4mad
2008/09 EVOX EFI ECU:
Battery Voltage
Idle RPM
Vehicle Speed
Intake Sensor 44 deg c
Coolant Sensor 68 degC
MAP Sensor 102.4kpa
Airflow Sensor 1171.9 mV
APS Main 996.1 mV
TPS 722.7 mV
TPS max 4375.0mV
TPS(main) learn 859.4mV
TPS(sub) 4257.8mV
Ignition Advance 61CA
Injection Time 0.0ms
LTFT Bank1 -1.2%
STFT Bank1 0.0%
Knock Retard 0.0CA
Knock Learn 100%
VVT Intake 15.0CA
VVT Exhaust -25.0CA
Purge Relay Duty 0.0%
Throttle Actuator 6.7%
ETV Idle Open 0.7V (electronic throttle valve?)
ISC Learn (A/C off) 0.0 L/S
ISC Learn (A/C on) 0.0 L/S
Absolute Load 0.0 %
Accelerate Load 0.0%
Crank Signal Off
Airflow Sensor 0.40g/s
Front 02 Sensor 0.000V
Rear 02 Sensor 0.000V
APS 102 kPa
TPS relative 6.7%
TPS sub
APS Main 19.6%
APS Sub
Fuel Status 1 0LRV
Read/Clear EFI Trouble Codes
2008/09 EVOX ABS ECU
Longitudinal G-Sensor 0.000G
Horizontal G-Sensor 0.022G
Yaw Rate sensor 0.0
Brake Level Switch NORMAL
Engine RPM 0.0 rpm
Engine Torque 0.0Nm
Expected Gear Value D N R
Current Gear Value R D
Brake Sensor OFF
Horizontal G-Sensor Offset Value -0.007G
CVI Oil Temp
Primary Gear Speed 4096 r_min
real engine torque
correct engine torque
input torque
gear position 1st
Read/Clear ABS Trouble Codes
but with this beta10 release you have much much much less. So where you even logging the above items last month?
Old Apr 11, 2009 | 10:56 AM
  #517
mrfred's Avatar
OpenPort2.0 + EvoX/CAN Notes:
Select OpenPort2.0 radio button, select EvoX/CAN radio button, the baudrate is 500000, select ECU as EvoX
To read some values from EvoX/CAN, you must change the trailing number. there is a possibility of 4 bytes that are returned from each CAN request, for example CAN0-0, CAN0-1, CAN0-2, and CAN0-3, then the sequence continues with CAN1-0, CAN1-1, CAN1-2, CAN1-3, CAN2-0, etc until CAN25-3
you will find CAN2-0 = CAN3-0 = CAN4-0 = CAN5-0 are the same, I just gave them a number that is in sequence for the dataitems. (etc, also CAN2-3 = CAN3-3 = CAN4-3 = CAN5-3)
This is kind of a bummer. There is a MUT table in the Evo 10 ROM, but I have not found a "CAN table" that maps the engine control parameters to the CAN. I was hoping that there would be a relationship between the CAN request IDs and the ordering of data in the MUT table, but there's no obvious relationship. So a few questions:
1) Have you found a "CAN table" like the MUT table?
2) If no to question #1, does the CAN use the MUT table?
3) If yes to question #2, can you explain your CAN request IDs a little better? It sounds like you have made up your own nomenclature.
Old Apr 11, 2009 | 05:20 PM
  #518
evo4mad's Avatar
Hi mrfred, I don't know anything about a mut table for evox sorry, it just uses the standard CAN protocll nothing to do with MUT. are you on msn messenger? we can try and work it out, I am always online every day.
Old Apr 11, 2009 | 05:27 PM
  #519
evo4mad's Avatar
Originally Posted by tephra
cool
Is this beta10 or beta11? (title bar says 11)
For the benefit of others you need to unzip this INTO your existing evoscan 2.5 directory.
I suggest you backup the 2.5 install first
Hamish - Can you explain how CAN logging differs from MUT? The X still has a MUT_TABLE so presumably MUT logging still works?
ok yes it can be beta11 that was a mistake. it was meant to be beta10, I will make the next one beta12, or a full release would be better. Any here tried the openport 2.0 logging for Evo9 and earlier?
CAN logging is very different to MUT, EvoX doesn't appear to use the MUT_TABLE.
no sorry, mut logging does not work, I tried it.
Old Apr 11, 2009 | 05:28 PM
  #520
evo4mad's Avatar
yes I was logging them on a mitsubishi MUTIII, how do you think I got the valid values
you forgot to take into account the double ups on TPS and APS, you only need it once. most are justa double ups of the ones above but with a different formula such as raw Voltage and %
Old Apr 11, 2009 | 10:08 PM
  #521
mrfred's Avatar
I found a series of three tables that contain some key engine control parameters. There is some other data in the table as well. There are a total of 49 sets of entries. The RAM addresses listed in the tables come in pairs. For each pair of RAM addresses, the first one is the same in all three tables. I'm thinking that one or all three of these tables are the CAN logging data tables. I'm not seeing a correlation though between the info that Hamish PMed me on the CAN logging identifiers and anything in these tables.
Here's all three tables side-by-side. Starting address in the ROM is shown in the first row.
Code:
0x9E7C				0xA250				0xA624
.short	1			.short	1			.short	1
.short	0xFFFF		        .short	0xFFFF			.short	0xFFFF
.short	0			.short	0			.short	0
.word	CTS_LU1_808642		.word	CTS_LU1_808642		.word	CTS_LU1_808642
.word	unk_80596E		.word	unk_805EC8		.word	unk_806422
.short	2			.short	2			.short	2
.word	BARO_ADC_C2_8086E4	.word	BARO_ADC_C2_8086E4	.word	BARO_ADC_C2_8086E4
.word	unk_805974		.word	unk_805ECE		.word	unk_806428
.short	3			.short	3			.short	3
.word	IATS_TEMP_80865A	.word	IATS_TEMP_80865A	.word	IATS_TEMP_80865A
.word	unk_80597A		.word	unk_805ED4		.word	unk_80642E
.short	4			.short	4			.short	4
.word	unk_80873A		.word	unk_80873A		.word	unk_80873A
.word	unk_805980		.word	unk_805EDA		.word	unk_806434
.short	0x11			.short	0x11			.short	0x11
.word	OCTANE_CALCED_80459E	.word	OCTANE_CALCED_80459E	.word	OCTANE_CALCED_80459E
.word	unk_805986		.word	unk_805EE0		.word	unk_80643A
.short	0x12			.short	0x12			.short	0x12
.word	unk_804572		.word	unk_804572		.word	unk_804572
.word	unk_80598C		.word	unk_805EE6		.word	unk_806440
.short	0x13			.short	0x13			.short	0x13
.word	unk_804574		.word	unk_804574		.word	unk_804574
.word	unk_805992		.word	unk_805EEC		.word	unk_806446
.short	0x14			.short	0x14			.short	0x14
.word	unk_804576		.word	unk_804576		.word	unk_804576
.word	unk_805998		.word	unk_805EF2		.word	unk_80644C
.short	0x15			.short	0x15			.short	0x15
.word	unk_809982		.word	unk_809982		.word	unk_809982
.word	unk_80599E		.word	unk_805EF8		.word	unk_806452
.short	0x16			.short	0x16			.short	0x16
.word	unk_809984		.word	unk_809984		.word	unk_809984
.word	unk_8059A4		.word	unk_805EFE		.word	unk_806458
.short	0x17			.short	0x17			.short	0x17
.word	unk_809986		.word	unk_809986		.word	unk_809986
.word	unk_8059AA		.word	unk_805F04		.word	unk_80645E
.short	0x21			.short	0x21			.short	0x21
.short	0x3E8			.short	0x3E8			.short	0x3E8
.short	6			.short	6			.short	6
.word	SPD_1B?_8087E6	        .word	SPD_1B?_8087E6	        .word	SPD_1B?_8087E6
.word	unk_8059B0		.word	unk_805F0A		.word	unk_806464
.short	0x23			.short	0x23			.short	0x23
.word	TRGT_IDLE_808AE4	.word	TRGT_IDLE_808AE4	.word	TRGT_IDLE_808AE4
.word	unk_8059BA		.word	unk_805F14		.word	unk_80646E
.short	0x24			.short	0x24			.short	0x24
.word	unk_80998E		.word	unk_80998E		.word	unk_80998E
.word	unk_8059C4		.word	unk_805F1E		.word	unk_806478
.short	0x28			.short	0x28			.short	0x28
.short	0xC8			.short	0xC8			.short	0xC8
.short	0x1F			.short	0x1F			.short	0x1F
.short	5			.short	5			.short	5
.word	unk_80954E		.word	unk_80954E		.word	unk_80954E
.word	unk_8059CE		.word	unk_805F28		.word	unk_806482
.short	0x29			.short	0x29			.short	0x29
.word	MAP_ADC_S_8086E0	.word	MAP_ADC_S_8086E0	.word	MAP_ADC_S_8086E0
.word	unk_8059F2		.word	unk_805F4C		.word	unk_8064A6
.short	0x2C			.short	0x2C			.short	0x2C
.word	N4_ADC_MAF?_808F4E	.word	N4_ADC_MAF?_808F4E	.word	N4_ADC_MAF?_808F4E
.word	unk_805A16		.word	unk_805F70		.word	unk_8064CA
.short	0x32			.short	0x32			.short	0x32
.short	0x64			.short	0x64			.short	0x64
.short	0x3D			.short	0x3D			.short	0x3D
.short	0xA			.short	0xA			.short	0xA
.word	LD_1B_NC_808762	        .word	LD_1B_NC_808762	        .word	LD_1B_NC_808762
.word	unk_805A3A		.word	unk_805F94		.word	unk_8064EE
.short	0x33			.short	0x33			.short	0x33
.word	NF_ADC_TPS?_809504	.word	NF_ADC_TPS?_809504	.word	NF_ADC_TPS?_809504
.word	unk_805A7C		.word	unk_805FD6		.word	unk_806530
.short	0x34			.short	0x34			.short	0x34
.word	unk_80952E		.word	unk_80952E		.word	unk_80952E
.word	unk_805ABE		.word	unk_806018		.word	unk_806572
.short	0x35			.short	0x35			.short	0x35
.word	unk_809998		.word	unk_809998		.word	unk_809998
.word	unk_805B00		.word	unk_80605A		.word	unk_8065B4
.short	0x36			.short	0x36			.short	0x36
.word	unk_80953A		.word	unk_80953A		.word	unk_80953A
.word	unk_805B42		.word	unk_80609C		.word	unk_8065F6
.short	0x37			.short	0x37			.short	0x37
.word	TPS_1B_N1_809622	.word	TPS_1B_N1_809622	.word	TPS_1B_N1_809622
.word	unk_805B84		.word	unk_8060DE		.word	unk_806638
.short	0x38			.short	0x38			.short	0x38
.word	FO2_NET_808668          .word	FO2_NET_808668          .word	FO2_NET_808668
.word	unk_805BC6		.word	unk_806120		.word	unk_80667A
.short	0x39			.short	0x39			.short	0x39
.word	unk_809990		.word	unk_809990		.word	unk_809990
.word	unk_805BEA		.word	unk_806144		.word	unk_80669E
.short	0x3A			.short	0x3A			.short	0x3A
.word	unk_808D6A		.word	unk_808D6A		.word	unk_808D6A
.word	unk_805C0E		.word	unk_806168		.word	unk_8066C2
.short	0x3C			.short	0x3C			.short	0x3C
.word	unk_808A06		.word	unk_808A06		.word	unk_808A06
.word	unk_805C32		.word	unk_80618C		.word	unk_8066E6
.word	unk_8094A0		.word	unk_8094A0		.word	unk_8094A0
.word	unk_805C74		.word	unk_8061CE		.word	unk_806728
.short	0x3F			.short	0x3F			.short	0x3F
.word	unk_808B4E		.word	unk_808B4E		.word	unk_808B4E
.word	unk_805C98		.word	unk_8061F2		.word	unk_80674C
.short	0x41			.short	0x41			.short	0x41
.word	unk_8094A2		.word	unk_8094A2		.word	unk_8094A2
.word	unk_805CBC		.word	unk_806216		.word	unk_806770
.short	0x42			.short	0x42			.short	0x42
.word	unk_809994		.word	unk_809994		.word	unk_809994
.word	unk_805CE0		.word	unk_80623A		.word	unk_806794
.short	0x93			.short	0x93			.short	0x93
.word	unk_80450C		.word	unk_80450C		.word	unk_80450C
.word	unk_805D16		.word	unk_806270		.word	unk_8067CA
.short	0x94			.short	0x94			.short	0x94
.word	unk_8099A8		.word	unk_8099A8		.word	unk_8099A8
.word	unk_805D1C		.word	unk_806276		.word	unk_8067D0
.short	0x95			.short	0x95			.short	0x95
.word	unk_805D22		.word	unk_80627C		.word	unk_8067D6
.short	0x96			.short	0x96			.short	0x96
.word	NULL_TPS_V?_804510	.word	NULL_TPS_V?_804510	.word	NULL_TPS_V?_804510
.word	unk_805D28		.word	unk_806282		.word	unk_8067DC
.short	0x97			.short	0x97			.short	0x97
.word	unk_8099AC		.word	unk_8099AC		.word	unk_8099AC
.word	unk_805D2E		.word	unk_806288		.word	unk_8067E2
.short	0x99			.short	0x99			.short	0x99
.word	unk_8099AA		.word	unk_8099AA		.word	unk_8099AA
.word	unk_805D3E		.word	unk_806298		.word	unk_8067F2
.short	0x9A			.short	0x9A			.short	0x9A
.word	unk_8099AE		.word	unk_8099AE		.word	unk_8099AE
.word	unk_805DBC		.word	unk_806316		.word	unk_806870
.short	0x9B			.short	0x9B			.short	0x9B
.word	unk_804688		.word	unk_804688		.word	unk_804688
.word	unk_805E3A		.word	unk_806394		.word	unk_8068EE
.short	0x9C			.short	0x9C			.short	0x9C
.word	unk_80468A		.word	unk_80468A		.word	unk_80468A
.word	unk_805E40		.word	unk_80639A		.word	unk_8068F4
.short	0x9D			.short	0x9D			.short	0x9D
.word	unk_80468C		.word	unk_80468C		.word	unk_80468C
.word	unk_805E46		.word	unk_8063A0		.word	unk_8068FA
.short	0x9E			.short	0x9E			.short	0x9E
.word	unk_80468E		.word	unk_80468E		.word	unk_80468E
.word	unk_805E4C		.word	unk_8063A6		.word	unk_806900
.short	0xA1			.short	0xA1			.short	0xA1
.word	unk_80999E		.word	unk_80999E		.word	unk_80999E
.word	unk_805E52		.word	unk_8063AC		.word	unk_806906
.short	0xA2			.short	0xA2			.short	0xA2
.word	unk_8099A0		.word	unk_8099A0		.word	unk_8099A0
.word	unk_805E58		.word	unk_8063B2		.word	unk_80690C
.short	0xA3			.short	0xA3			.short	0xA3
.word	unk_8099A2		.word	unk_8099A2		.word	unk_8099A2
.word	unk_805E5E		.word	unk_8063B8		.word	unk_806912
.short	0xA4			.short	0xA4			.short	0xA4
.word	unk_8099A4		.word	unk_8099A4		.word	unk_8099A4
.word	unk_805E64		.word	unk_8063BE		.word	unk_806918
.short	0xA5			.short	0xA5			.short	0xA5
.short	0x1F4			.short	0x1F4			.short	0x1F4
.short	0xD			.short	0xD			.short	0xD
.word	unk_8095D2		.word	unk_8095D2		.word	unk_8095D2
.word	unk_805E6A		.word	unk_8063C4		.word	unk_80691E
.short	0xA6			.short	0xA6			.short	0xA6
.word	unk_809596		.word	unk_809596		.word	unk_809596
.word	unk_805E88		.word	unk_8063E2		.word	unk_80693C
.short	0xA7			.short	0xA7			.short	0xA7
.word	unk_80959A		.word	unk_80959A		.word	unk_80959A
.word	unk_805EA6		.word	unk_806400		.word	unk_80695A
Old Apr 11, 2009 | 10:18 PM
  #522
tephra's Avatar
You might be better looking at the CAN registers/instructions in the ECU as a starting point for tracing the CAN stuff...
There was only 1 place that the ECU refers to the MUT_TABLE, so I don't think there will be a MUT->CAN or vice-versa translation.
Hamish - Where/how did you come up with your current list of CAN ids -> logging item?
Old Apr 12, 2009 | 12:20 AM
  #523
Tried logging with this today, kind of useless at this point unfortunately.
Tephra, MrFred, Gunzo, etc, I would love to see what you all think of this, and of course, if any testing needed, I would love to help as much as possible.
Old Apr 12, 2009 | 05:20 AM
  #524
evo4mad's Avatar
[QUOTE=tephra;6928799]You might be better looking at the CAN registers/instructions in the ECU as a starting point for tracing the CAN stuff...
QUOTE]
are you on msn messenger today? we can talk about it for a few hours if you have time, we can figure more out.
Old Apr 12, 2009 | 05:29 AM
  #525
evo4mad's Avatar
GST motorsports I gotta love your negativity:
"So where you even logging the above items last month?"
"kind of useless at this point"
EvoScan is always the best datalogging software for Mitsubishi, just happened that PCMScan fluked it by having generic CAN support, you just wait and see, EvoScan will surpase PCMScan by miles.
Yes please test it, link is above in POST#1, there have been no comments made by you about the accuracy on the current version and requests, so you are saying they work ok? that is a huge step forward if it even logs something, considering its the first version I've ever programmed CAN protocol. Can you compare it between PCMscan and tell me if the values are perfectly the same? If so, thats excellent, its a basis for extending it beyond the generic scantools, which EvoScan always does.
