EvoScan v2.6 And New EvoScan GPS/Logger/Reflashing Touchscreen Review
Old Mar 18, 2010 | 12:36 PM
  #1276
rogue's Avatar
What is the newest beta driver? -
J2534 DLL Version: 0.50.2772 Nov 7 17:12:46
If this is the latest then it comes up in Windows 7 for me as a Com4 device.
Old Mar 18, 2010 | 01:35 PM
  #1277
rogue's Avatar
Ahh nevermind... i found another update...
Old Mar 20, 2010 | 05:10 PM
  #1278
_Speedy_'s Avatar
Originally Posted by newcomer81
as a heads up to those who are working with Hamish towards the final 2.7; the newest beta drivers for the tactrix OP 2 cable are not compatible with EvoScan. Under the Device manager it no longer shows up listed as a com port. it is now in its own new group "Vehicle PassThru Interfaces"
what error do you get, just cause its got a new usbser.sys instead of the microsoft one, doesn't make any difference does it? Evoscan works just fine on evo8 with new driver versions..
Attached Thumbnails EvoScan v2.6 And New EvoScan GPS/Logger/Reflashing Touchscreen Review-screen_220.gif   EvoScan v2.6 And New EvoScan GPS/Logger/Reflashing Touchscreen Review-screen_218.gif   EvoScan v2.6 And New EvoScan GPS/Logger/Reflashing Touchscreen Review-screen_219.gif
Old Mar 20, 2010 | 05:21 PM
  #1279
_Speedy_'s Avatar
http://www.tactrix.com/downloads/ecu...1_win_beta.exe
--1.10.2938
* IMPORTANT - the OP2 now uses a custom driver I wrote for better speed and stability than the Microsoft usbser.sys driver. This allows for reduced latency and a cleaner installation as well. *** This means that initially you must do a full EcuFlash and J2534 / driver install so that all of these components will work together. OLDER ECUFLASH AND OP20PT32.DLL VERSIONS WILL NOT WORK WITH THE DRIVER. **
it goes EvoScan -> op20pt32.dll -> usbser.sys -> op2 -> ecu
now
EvoScan -> op20pt32.dll -> op2 -> ecu
I'm sure EvoScan will still work.. its just a new firmware on the op2, and a new op20pt32.dll, evoscan uses the op20pt32.dll from what I can tell. so really, the new op20pt32.dll on first use will upgrade the firmware on the op2 cable. just means you can't use that op2 cable on another computer without the latest op20pt32.dll
Old Mar 21, 2010 | 01:13 AM
  #1280
crimson red's Avatar
Hello,
After starting to use EcuFlash1.43beta to avoid blue screen which often occur on my XP SP3, I've never been able to use EvoScan2.7beta5(last open beta released about 6 monthes ago) and other J2534 loggers. Because I'm not one of the lucky closed beta tester of EvoScan 2.8beta.
I'm looking forward to getting a 2.8 open beta or release as soon as possible.....
Old Mar 22, 2010 | 12:54 AM
  #1281
Smile found a solution of my problem
I found a solution of this.
EvoScan has another copy of op20pt32.dll in its own folder. As you know, current folder has the highest priority to search and execute a requested dll.
Solution:
1. Install EcuFlash1.43beta. New version of op20pt32.dll driver is installed into your windows system folder(likely windows/system32/).
2. Just remove or replace op20pt32.dll in EvoScan folder. EvoScan 2.7beta5 will be executable again.
BTW, After solve that, I've taken a test drive for some hours. No blue screen was showed. I can't say 'absolutely' yet, but it may be disappeared. Thanks to develop new driver!
Old Mar 23, 2010 | 11:37 AM
  #1282
newcomer81's Avatar
^^ worked for me with the latest 2.7, i think its the final beta. certainly newer than beta5
Old Mar 24, 2010 | 09:03 AM
  #1283
leecavturbo's Avatar
any progress on the gps logger features ?
Old Mar 25, 2010 | 06:41 PM
  #1284
markyang83's Avatar
hi Hamish
I just bought a couple of EvoScan GPS Navigator from you, will this work with tactrix open port 2.0?
many thanks
mark
Old Mar 26, 2010 | 11:35 AM
  #1285
SoCal Rally's Avatar
Planned release date for v2.7 final?
Old Mar 31, 2010 | 06:43 PM
  #1286
olsookie's Avatar
quick question for everyone, with evoscan v2.6 and up we no longer need to edit the rom file for mode 23 is that correct? as long as we select evo x as the ecu type I am good to go?
Old Mar 31, 2010 | 06:50 PM
  #1287
rogue's Avatar
Untrue....
You must use ECUFLASH, a separate application, to enable mode 23 on your ROM. You will then use EVOSCAN to take advantage of Mode 23 being enabled.
Old Mar 31, 2010 | 07:31 PM
  #1288
colby's Avatar
The new driver should definitely fix any blue screens - that's why I wrote it!
Solution:
Old Apr 1, 2010 | 07:34 AM
  #1289
Mellon Racing's Avatar
link to 1.43 beta?
Old Apr 1, 2010 | 08:34 AM
  #1290
evonut270's Avatar
Originally Posted by Mellon Tuning
link to 1.43 beta?
Here
http://www.tactrix.com/index.php?opt...d=44&Itemid=65
