i have a jdm 8mr and can get access to a OP2 cable. if u guys need a rom of my car.
what could be intresting is to get a hold of the ralliart tarmac or gravel spec ACD controlers. a question who do people want to switch off AYC but leave the ACD on? |
https://www.evolutionm.net/forums/ev...everybody.html
Forum ACD FAQfor reference
Originally Posted by ziad
(Post 7983266)
The Gruppe S flash also disables the ayc (if there is one)
Based on this comment in the wikipedia entry for AWC I'll assume that the ROMs are different between the VIII and IX (because, you know... Wikipedia knows everything).
http://en.wikipedia.org/wiki/Mitsubi...ncer_Evolution Lancer Evolution IX also uses a revised AWC system that is even more pro-active than in previous generations. On the Evo VIII, the AWC system gave priority to the Sport ABS system in order to stabilise the car under heavy braking. The ACD and Super AYC modules were effectively disengaged. The AWC system has been revised so that the driving force is still controlled actively, even when the Sports ABS is operational. |
Originally Posted by fostytou
(Post 7983712)
http://en.wikipedia.org/wiki/Mitsubi...ncer_Evolution |
well if acronyms tell u everything. the 8Mr/9s got the SAYC while the previous got the AYC so that part of the ecu could be different ;)
3 Attachment(s)
Evo8 ACD definition so far.
Download -> Attachment 147158 All 3D tables defined. Correct axis are attached to tables, but scalings not found yet. Added Hex ROM Id, to EcuFlash header, for differentiation between minor versions. 4014 is rom name, 03 is minor revision. Tables are named like A1.1, A1.2, A1.3, A2.1, A2.2, A2.3. A1.1 A is the table group. A1.1 1 is switched in the ecu by something I have not found yet. A1.1 .1 is switched by Tarmac, Gravel, Snow. Not sure of order yet. So there are six tables in group A, but only one will be used. Attachment 147152 Attachment 147159 If someone can please log the ACD with EvoScan. Then I can find the scalings for the axis, and what the tables do. There are also 30-40 2D tables, but without knowing what they do its pointless to add them. |
1 Attachment(s)
dont know if this will be correct but i had a little play with the table addresses and scalings and came up with this for the main table.im still new to dissassembly
i am excited and well worried (more tables to learn) :lol:
Evonut, not entirely sure that the Y axis would be 122.5% TPS angle. The hex value 3972 is referenced in almost all the other tables it seems though.
Originally Posted by Ceddy
(Post 7984772)
Originally Posted by GST Motorsports
(Post 7983263)
I have a spare 2005 Evo 8 ACD ECU if it's needed for any testing - Bryan I believe it would speed up the development on this part. |
Originally Posted by JohnBradley
(Post 7985678)
Originally Posted by acamus
(Post 7986137)
ECU PIN 79 - ACD PIN 36 seems to be Idle position signal 0-1V idle, 4V-more open throttle
I think it is good that more people to start downloading they're roms to make a small database of roms and see how many different one exists. I'm starting to see my dream come true about tuning this ECU. S. |
(Post 7983083)
http://www.gems.co.uk/?content=pages...ontrol-systems
http://www.motec.com.au/mdc/mdcoverview/ Looking at the other tables they are maybe versus slip angle? One would be longitudinal and the other might lateral vs steering wheel position? Not sure on them. Anyone with the MOTEC ECU willing to pull the ROM? It seems the same/similar hardware is used. Maybe we could disassemble it as well :P |
