I dont use corrected dyno numbers, just the number the car made on the particular day it was on the dyno. Correction is for comparison only from one dyno to another, if the car went out on the street in 96* heat it doesnt make a corrected number it makes the uncorrected number. Its not to discredit the power as its 20whp difference. On a colder day it would be 1014, yes.
Those pictures are the real definition of car porn.
That intake manifold is another brand though they just use as a starting point. Not everything they make is from scratch. Definitely interested to see how much it makes with more boost. Also I do understand this cars only intent is to make record breaking dyno HP numbers and thats perfectly fine. Every car has its own reasons to exist. |
On behalf of ET team wants to thank you for welcome their car and your kind words.
what would this setup make with a front mount air to air intercooler? 1000 hp with only 2 more psi then a factory evo is pretty sick
needs wrong offset wheels, negative camber, ac kit but otherwise good job. oh and more loooooww |
I wish these ET cars would just put the runs down to prove their claims.
On the plus side, they posted actual Evo parts this time. Is that crank with removable counter weights meant only for developmental testing? |
Originally Posted by 03whitegsr
(Post 11282465)
On the plus side, they posted actual Evo parts this time. Is that crank with removable counter weights meant only for developmental testing? we dont have tracks here to support these cars. No glue and good track. they test this evo ix at 19-20psi and had 9.2sec @ 162 with 1.68 60ft. and all wheel spin. the crank is in this kit right now, they made lot of tests about this |
I think it's stuff like that though that just hurts more. There are cars here making 700hp that run better times, some on less than great tracks and others are "street cars."
ET aside... 19-20 psi and 162mph traps is a huge claim. FWIW though, US cars claiming similar power are trapping high 160 range. I have no idea on weight of this car though... Interesting on the crank though. That's the last place I'd want hardware holding on weights. Thought maybe it was just an effort to use one crank to test multiple rods/piston setups by using replaceable weights. For something permanent, I'd think they'd do tungsten slugs parallel with the crank axis. |
24psi at 12k is why its making power. All about the CFM...why 7.3psi on the mid 90s Indy cars could make 900whp on a 2.65L
Originally Posted by stamatis evo6
(Post 11282648)
From nearly a decade ago, an early EVO (albeit tube framed, but making the exact same power level and putting down 8.2-8.4 range at nearly 180mph on a dusty airstrip with a dirty old rebuilt stock gearbox (no 8 speed sequential here) - sure its going to be a fair bit lighter, but not 1 second and 20mph worth of lighter: |
(Post 11283269)
ET aside... 19-20 psi and 162mph traps is a huge claim. FWIW though, US cars claiming similar power are trapping high 160 range. I have no idea on weight of this car though... Interesting on the crank though. That's the last place I'd want hardware holding on weights. Thought maybe it was just an effort to use one crank to test multiple rods/piston setups by using replaceable weights. For something permanent, I'd think they'd do tungsten slugs parallel with the crank axis. 5'' exhaust pipe to tail, 152lbs IC kit with water and ice included full + 20ltr tank, 79lbs turbo, dry sump kit extra oil tank and exhaust manifold, 10pot 380mm discs frond and 6pot 356mm disc rear. |
Originally Posted by MrLith
(Post 11283306)
We don't either, here in NZ - and we have some of the quickest 4WDs in the world!
From nearly a decade ago, an early EVO (albeit tube framed, but making the exact same power level and putting down 8.2-8.4 range at nearly 180mph on a dusty airstrip with a dirty old rebuilt stock gearbox (no 8 speed sequential here) - sure its going to be a fair bit lighter, but not 1 second and 20mph worth of lighter: Docile - YouTube Tokoroa Dragway Amisfield Airfield Moffat Rd Tokoroa Taupo Thunder Dragway Taupo Motorsport Park Off Rd Hwy Masterton Motorplex South Road Masterton Nelson Rock FM Dragway Marchwood Park Rd Motueka Nelson Southern Dragways Alexandra airport the pass show us from this car (i dont know what car is it) at this pass dont even make below 10sec. have you seen this pass? Must be 1900<lbs and its drag car. ET evo ix as you see at the above post its street car full interior. But please stop compare aples to oranges. At this topic i show you engine setup-technology only. |
Prolly cleanest and the sickest builds I've ever seen
Aaron...I know HOW somebody could do it...although, seriously, do the math on it and you'll see that it's still like 120% VE to make their claims...correcting for typical power gains of methanol and thermal efficiency of 17:1 compression...
I'm sure you've calculated/measured out VE before on some cars that roll through your shop...how many make 120% VE ANYWHERE in the RPM range? Much less 12k RPM... I've personally seen ~112%VE at peak torque on a EJ25 GT42R setup with long tube divided exhaust manifold and an intake manifold tuned for peak torque around 6500 RPM. That car had heads that were WELL over 300CFM on the intake side with an intake cam that was over 300* advertised duration... |
(Post 11284260)
Originally Posted by JohnBradley
(Post 11284532)
I personally like the 23-24cc dome piston in the 1.9L{pcfreak}
I ask for you also here are the details of the engine they gave me :thumbup: 4g64 block 87mm piston bore 79mm stroke crank 1878cc 168mm rod length 27.5mm piston compression height titanium pins -25.2cm3 piston dome 16.92:1 compression ratio with flat titanium valves no relief |
