Originally Posted by Evo8life
(Post 11807015)
I only have surge at light throttle in high gears i will be swapping MAF this saturday to see what happens
Originally Posted by 2006EvoIXer
(Post 11807016)
It doesn't make sense to get surges on light throttle. I can see you WGA duty cycle is all over the place too. How are you controlling boost? 3-port?
(Post 11807019)
im running a halmann manual boost controller.do they cause issues normally?i have never seen an mbc setup before my car all the cars i owned or my friends owned were electronically boost controlled,i noticed something that i need to turn the mbc too much to attain 24 psi between 21 -24 psi there is like 4 full turns
But before turning up the boost, we need to know why you're getting knock. Check your TPS. Your last log showed only 66% and timing was advanced to 11 degrees, IDC dropped, and AFR went to 14. Luckily, timing was pulled to -3. |
I will be installing a fuel pressure sensor to the car to be able to collect data about fuel pressure status that will help pointing out whete to start diagnosing the issue
try raising your load limits?
(Post 11807133)
(Post 11807135)
i already have them at 300 i think boost cut is not the correct word to describe the symptoms its more of a missfire
Side note, you should tweak your logs. You are logging too much stuff at once, and you are logging things you don't need to be. You should trim it down to only essential stuff and, If you aren't on a modded ROM (tephra) then you should probably setup your mut table to do 2byte load logging. You are logging a few different kinds of load which you don't need to be. There are alot of threads on doing both these things you can search for. Your logging will be faster if you do this. |
Actually Strike that, don't raise your limits. I think you should consider getting some professional help tuning the car, or spend a bunch of time reading up on logging and tuning in general before tweaking the safety measures in the ECU. Turn the boost down to where AFR's and knock are safe. There is literally everything you need to know to tune an evo in our ecuflash subforum. There is also this guide to get you started http://www.evoscan.com/ecuflash/Merl...UIDE-V1.7a.pdf
(Post 11807143)
(Post 11807145)
im not hitting load limit im sure as max load im hitting is 250 so im still so far away from 300.i know how to deal with the tune i have read and taken courses about efi tuning ,as for the logs you are right i need to remove unessential things and keep the most important things
(Post 11807147)
I don't know how you know that though, the most accurate load reading from a non modded rom is 2byte load and in your log that is reading like 5000 so clearly thats not setup correctly in the mut table.
(Post 11807148)
man just look at 1byte load im on tephra v7
(Post 11807151)
Oh didn't see that you where on v7 already, you are just logging like every type of load in evoscan so its a bit confusing.
do you have no lift to shift turned on? It almost looks like that is getting triggered or something.
(Post 11807154)
