vortex generator part#MZ380295EX
Thanks mitsupwr. I'm swamped with work at the moment and have not had the time to look this info up for the board users.
What is the part number for the '03 Evo's clock?
The GSR, RS, and MR all share the same cylinder head and camshafts. Part numbers are listed below:
Cyl Head: MN155744 Intake Camshaft: MN143619 Exhaust Camshaft: MN143620 Intake Manifold: MN137746 Exhaust Manifold: MN156302 Down Pipe: MN135583 Mid Pipe: MR968097 Rear Section: MN153192 I've already pointed this out elsewhere on the forums but the MR does in fact use a revised (larger) compressor housing compared to the RS/GSR trims. Everyone is already well aware of the turbine housing.. All models do in fact use the same CHRA however. CHRA: MD613507 '03-'04 All Trim levels Compressor Housing: MD613567 Turbine Houshing: MD613521 All '05 Trim levels Compressor Housing: MD613573 Turbine Housing: MD613524 ***Please note that the MR turbine housing uses the same O2 housing as the previous models. You do not need to purchase a "MR" housing. MR Wheel (17x8JJ +38): MN184113 |
Well. I changed my oil again, and this time I bought ramps so I did not spend 2 hours removing the plastic undercover....anyway, the part number on the oil filter on the MR was MD356000. The oil filter I bought from Mitsu was MZ690116. I compared them and #MD356000 was a little smaller than #MZ690116. I put the new one on, and it fit perfect. Which is the right one? I will probably continue to use #MZ690116 just because it is a little larger. Just curious....
The original filter off my EVO was MD356000 also. Mitsu recently switched to newer style oil filters across the board, so the original off your car was the old style. All new replacement filters are MZ690116. |
I took the tray off the first time because I am dumb. I could not find a place to jack it up, so I removed all of the undertray (like a dumb ass) to clear a spot to jack it up. This time I bought ramps and the oil change took ~ 20 minutes.
Thanks for the filter info!! |
Part number for the plastic housing arount the clock and hazard switch. It holds two vents too. Broke it mounting display for EVC.
Fog lights and switch
I bought an '05 without the foglights. Anyone know the part numbers required to install them?
-- switch -- relay? -- housing for foglight...I hope the whole headlight assembly doesn't have to be replaced. It will be interesting to see how much I can get this from Conicelli...I guess it might be cheaper to buy aftermarket lights and put them below the bumper somewhere. TIA, |
Originally Posted by JustDSM
MR512557
OK. Can someone explain to me why the EVO's that come from the factory have FULL carbon Fiber spoliers. Yet, the replacement spoiler my dealer got had plastic ends? I want a factory original, is this possible? The spoiler that came on my car was all carbon fiber and you can see the weave under the paint.
Can someone PLEASE find me a mitsu part number for the REAL carbon fiber spoiler that I can take to the dealer so they can order me the right one. |
Last time I compiled a list of all part numbers so far (that way we can see it all in one shot, instead of reading 8000 posts), I can do it again or if somebody else wants to take a turn? =)
-joe |
i was bored.. so here's all the part numbers so far:
MR633538 Upper Steering column cover MR232147 Gear link bushing MF247868 (1) MF140210 (3) MF140206 (6) Cam cover bolts MR572609 Board, trunk room floor MR444269 Trim, Trunk room RR end (Grey) MD050316 Oil drain plug MD569372 M/T plug MB547806 Clip, Engine Room Cover MZ690116 oil filter MR552951 air filter MR407376 Front pad kit (hardware sold separately) MR407391 rear pad kit " " MD979313 water pump MN158794 alternator belt MD186785 spark plug grommets MD340535 valve cover gasket MD152772 pcv valve MN132206 clutch disc MR980846 pressure plate MR145619 T/O bearing MD746617 clutch slave cylinder MR491945 clutch master cylinder MN149074 crankshaft pulley MR370723 front brake rotors MN153010 oxygen sennsor frt MR578532 rear oxygen sensor MD327107 cam position sensor MR578117 knock sensor MD363552 ignition coil MD343245 plug wires set MD374841 spark plugs MR455707 lug nuts MB911495 wheel studs (frt or rear) MR984375 timing belt adjuster MD369999 timing belt pulley MD569372 air intake rivet thingy MR288876 hood vent rivet thingy MR975089 coin box mn153356 BODY ASSY,AIR CLEANER (Stock Airbox) mr578399 SENSOR,AIR CLEANER (MAF SENSOR) MN153284 bov MN126274 Insulator, Hood MR475929 Left caliper MR475930 Right caliper MZ598263 CD Changer Install kit MR626799 cd changer panel only, no rails (black) MR554814 RH Lower Control Arm Asm. MR554813 LH Lower Control Arm Asm. (this is an assumption based on left right part#) MB914617 Front Wheel Bearing Asm. MD160689 1G Air bypass valve (for anyone using Buschur upper IC) MU480007 licence plate grommet (square) MN168249 Gear Shift Lever Retainer (part of the gearshift level) MR286178 Replacement trunk lock MR633547 panel with the shifter and ashtray and the cigarette lighter MN161463 RS ~04/07/31 trunk lid MN161464 RS 04/08~ trunk lid (no spoiler) MN150620 RS 04/08~ trunk lid (spoiler) MN161462 MR trunk lid (spoiler) MN161463 MR trunk lid (no spoiler) MR574731 front Mitsubishi symbol MR975477 intake/trunk carpeting fastener MB547806 front undertray fastener MB918617 tiny light that shines into the ash tray MN143213 stock boost solinoid located under the airbox MR412407 rs trunk bar MN101890 MR bilsteins Fronts MN101899 MR bilsteins Rears MR647677 the piece that holds the ashtray and the cig lighter MD372536 cam seals MN158794 Alternator and other drive belt MN153284 MR bypass valves MR970228 black RS door handles Front Right MR970227 black RS door handles Front Left MR970268 black RS door handles Rear Right MR970267 black RS door handles Rear Left MR450703 donut gasket for the downpipe MR481252 radiator cap MR250558 Radio delete panel MR597271 downpipe bolts MR597273 downpipe Springs MR497545 studs on the cat MR571083 downpipe -> cat (nuts that go on the studs on the cat) MF241309 cat -> cat-back bolts + nuts MR627152 interior door handle Front Left MR627153 interior door handle Front Right 1545A001 MR BOV MD345681 Rocker cover center cover MN161534 rear side marker light MR648031 rear interior door panel (which side?) MR973540 antenna Base MR583214 antenna Nut MR587268 stock radio (evo?) MD000312 transmission drain plug gasket MF660036 trasmission fill plug gasket MD000312 transfer case drain plug gasket MD000312 transfer case fill plug gasket MB001294 rear diff. drain plug gasket MF660036 rear diff. fill plug gasket MR506482 headlight height adjustment switch MN126920HB 3rd stoplight cover (You have to get the whole light assy.) MR580533 teflon shifter cables MR MN107670 teflon shifter cables GSR/RS MN143079 timing belt cover lower front MN153353 Air Cleaner box cover (top) MD613573 MR Specific Compressor housing MD613524 MR Specific Turbine housing MD613567 GSR/RS Specific Compressor housing MD613521 GSR/RS Specific Turbine housing MZ380295EX vortex generator MN155744 Cyl Head MN143619 Intake Camshaft MN143620 Exhaust Camshaft MN137746 Intake Manifold MN156302 Exhaust Manifold MN135583 Down Pipe MR968097 Mid Pipe MN153192 Rear Section MR962799 03 Evo's clock MD356000 MR oil filter MZ690116 oil filter (normal?) MR512557 plastic housing arount the clock and hazard switch -joe |
