Originally Posted by hkfeet
Front o2 sensor
Rear o2 sensor MN153010 Front O2 sensor MR578532 Rear O2 Build 12/02 to 08/03 (Probably old-style before recall) MN191125 Rear O2 Build 09/03 on (Probably supercedes above number and is post recall) |
del
del
05 Passenger Front Fender Side Marker Lens
timzcat,
sorry but do you have any part list for the evoVII? have been trying to find it but to no avail. and also the colour code for the pearl white original paint of the Evo VII GT-A thanks. |
no, only have usdm part #'s
Originally Posted by JustDSM
Lower cussion: MN151113XA
Back cussion: MN151111XA Also, the foam is not avail. seperately from the material. You've got to buy it complete. ths |
question on how the system seperates the brake lines. Went to install aftermarket lines to replace the rubber ones, but as soon as i put a wrench on the 10 mm holder bolt, it just rounded like icing on a cake.
Not an issue now, but the lines aren't installed now. couldn't bust it loose, so nothing could be done. Quick version. How does mitsu seperate the metal lines from the distributing block to the connection by the wheel? Fronts esp. Thanks.
Originally Posted by timzcat
What is it you want?
Part number for the hardline? Would need both fronts, and the nut. (well, the nuts would be on it if it came pre-flared.) |
i want a new trunk painted in silver...is there a part # for this?
MN161463 RS ~04/07/31 trunk lid
MN161464 RS 04/08~ trunk lid (no spoiler) MN150620 RS 04/08~ trunk lid (spoiler) MN161462 MR trunk lid (spoiler) MN161463 MR trunk lid (no spoiler) i called my dealership...i have a gsr...they said the correct trunk part # for me is mn161462....if i order will it come with the holes or without the holes? |
I would like to find the part number for both headlights for an 05 evo w/o the ssl package.(non hid)
Thanks |
What is the part number for a set of replacement climate control knobs? Or if they are sold individually, just the two big ones (not the fan speed knob).
l8r) |
Looking for the part number for the plastic gas pedal. Would I need it if I get the sport pedals?
what is the part number for poppet fastners?
need p/n for:
1. Intercooler sprayer nozzle 2. Intercooler sprayer's tubing |
