Originally Posted by 420a-t
(Post 9832945)
What lbs/min you hitting? I could go as far as 34 psi on my hta green on e85 and was still fine. Are you on the fp black?
To give a little more comparison i did not see the limits of this pump when i was flowing 54lbs/min with a rewire and an afpr.
Fp black is a 68lb/min turbo if that's what your looking for. I don't have my laptop so I'm not sure if this is something you can log.
Thanks guy for the how to I just finished installing it and everything worked fine
Good to hear
great write up{thumbup}
Is it possible to run the rewire without a tune? Probably just be dumping a lot of fuel for that week before I get tuned right? Was looking to run my 1680 and rewire on pump before I can get tuned.
Originally Posted by Itchy
(Post 10006902)
1680cc injectors? If you can at least set the scalings and latency in the ecu, otherwise I'd just wait till you can be tuned before installing them. But as far as the rewire yes you can, you will be running pig rich but it is possible. Just wouldn't get into boost that much. Is it a 255fp? Btw, very nice write up wizzo! |
I wouldn't drive with the new injectors. Rewire yes you can but it will be running rich. When I did my rewire I drove it for about a week before I got a fuel pressure regulator to set the fuel pressure. It didn't run very well for that week.
Thanks nytalonTsi |
WIZZO 8 is a saint!!! I searched for hours to find this! Great write up!
Great write up. How did you guys run your power wire from the engine bay? After debating several furewall options I opted to run mine along the ECU harness through the fenderwell, into the ECU/kick panel area. Bless :mitsu: for all the space they left on the door sills for wires like this. I couldn't take pics because my GF had the camera tonight. In the future I will probably build a new wire loom for all the wires to run through the chassis tube inside fender well.
I ran mine on the drivers side behind the fender, into the car, and then under the carpet by the door sills. Mine is still working great without any problems.
Finished all the steps carefully and my pump won't turn on now. I'm supposed to leave the two skinny black wires alone right? I checked the power wire, fuse, ground, connections, it's all right. I soldered them all according to the instructions but it just wont prime now. I'm not sure what to do.
Oh yeah, and I LOVE the fuel pump assembly retainer ring and how easily it comes in and out of the hole in the chassis (sarcasm). That has to be the single most retarded part of the Evo. What a PITA. Waste of time and effort. |
Originally Posted by hokiruu
(Post 10314722)
Nice writeup!
