Originally Posted by EVOXHOG
(Post 11737992)
Awesome results! How long will the stock block last on this kind of power before it gives and needs to be built? Thanks!
Originally Posted by razorlab
(Post 11734683)
It would probably shoot the wheel out before 35psi up top.
The only real way to know the answer to that is to log the turbo shaft speed with the speed sensor.
Also the question varies based on where you're talking about holding boost. Low rpm vs high RPM, etc. The turbo says its 64lb/min so probably around 30psi on a 2.0L. |
have you ever seen a 7670 or smaller EFR turbo loose its wheels due to overspeed? So far I've only heard of the 9180 doing it?
Originally Posted by ddlopresti
(Post 11744816)
Originally Posted by tscompusa
(Post 11735463)
I would contact CBRD. Maybe you have one of your oil lines setup wrong or some kind of restrictor isn't in place.
This car doesn't burn any oil at all, and this turbo works great. This is a very very smooth car. Anyone with a X looking for close to or right around 500WHP dynojet on e85 with stock cams should definitely consider this turbo kit. |
