Originally Posted by vadimus_ca
(Post 10999610)
Get a cable, I can do it remotely.
http://www.ebay.com/itm/121169948216...84.m1497.l2649 Once it arrives I'll let you know. Thanks! |
You're welcome :)
Originally Posted by dhatw
(Post 11000175)
Hi Vadimus, I have a 2012 Evo MR, would you be able to disable TPMS for me. I actually bought a Lexia kit but could never figure out how to get the software installed. I would be willing to pay of course then I would sell my Lexia.
Thank you, Wayne. |
(Post 10999610)
Trying to connect to my 2013 GSR...
Windows XP, Diagbox 5.29, sofware seems to work normally and it identifies the unit (checked it's on 4.2.4 FW). Drivers installed automatically via Windows and don't see any issues there. But no matter what I do, I can't get it to connect to the ECU via OBD. It asks for the VIN instead of reading it, and under the Global Tests each test says "no dialogue" and says no communication from ECU. I've checked all connections a million times and tried it with ignition on and off. I disabled the auto-update FW via editing the INI. |
(Post 11000610)
You're welcome :)
Originally Posted by GSXRiderK6
(Post 11001483)
Can you install the software remotely as well?
Originally Posted by 99EclipseGSX
(Post 11001512)
Windows XP, Diagbox 5.29, sofware seems to work normally and it identifies the unit (checked it's on 4.2.4 FW). Drivers installed automatically via Windows and don't see any issues there. But no matter what I do, I can't get it to connect to the ECU via OBD. It asks for the VIN instead of reading it, and under the Global Tests each test says "no dialogue" and says no communication from ECU. I've checked all connections a million times and tried it with ignition on and off. I disabled the auto-update FW via editing the INI. Try DiagBox 7.x. |
Originally Posted by Fastrax04
(Post 11012758)
Ok just got it! What are the steps I need to take to make sure it connects to my car? I have a 2013 GSR SS.
Or we can go on with whatever we have now, at your responsibility :) |
(Post 11012804)
I do not think it is feasible :)
(Post 11012812)
I would recommend to wait a couple of days, new database with better support for 2013 models is available and needs to be put into the program.
I will send you a link once it is available. I do not want this software to be fully available to public yet.
(Post 11012853)
My Lexia cable came with very poorly translated English from Chinese instructions. :confused:
I'll try to find something better. |
Will this help?
(Post 11001294)
Hi Vadimus are you able to turn off TPMS on Evo MRs?
Hey Vadimus, I'm curious about this questions as well. I remember a while back someone disabled their TPMS sensors on an MR with the Lexia unit but it caused all types of hell with other things for some reason. What are your thoughts? |
