Are you running a vacuum pump for the brake booster ? Have you considered installing a brake booster delete to avoid needing a vacuum source for braking ?
It seems that your driving around without power steering. Do you have plans to install one in the future or is your possibly lighter front end make it easier to steer when rolling? Perhaps use the EV West adapter plate with power steering or maybe make something similar and install the Evo OEM power steering pump (if you want to run ps)? Also, I was just brainstorming the idea of installing the alternator to run and charge accessories in the car. Would you be able to set it up to run a regular car battery or mini battery with an alternator to power the accessories of the car? Obviously the alternator will not do much when stationary, but when moving it could power the interior, accessories and charge the accessories battery etc... This way the main battery will just be used to accelerate and reduce power consumption.... |
No brake boosting at the moment, eventually I'll install a pump. I'm not interested in power steering for the EVO, it has great turn-in and I don't want to lose that feel. Alternator is an option and I've seen them used in other builds, but a DC-DC converter is more efficient overall. Right now my 12v and 200v packs are completely separate.
Video looks great man and the acrylic cover for the hood was genius. 100% power is coming sooner than later!
This is one of the most impressive and inspiring projects I have ever witnessed successfully seen to completion on the internet. Huge respect to you for the vision, ingenuity, and ability. Thank you for showing and sharing.
Any updates ?
Any updates on this?
How do you condition the batteries? |
Looks like Electron Bom, hasn't been on here in over a year now :(
If you ever see this thread again, please post updates! |
What happened to this build? Did it get registered? Is it still running? My motor is blown and I'm looking for options.
Last Activity: Dec 9, 2018 09:21 AM
Y u no drive video {pcfreak}
