another evo project
Old Jul 31, 2011 | 09:28 PM
  #91
mrboost05's Avatar
in this photo is the charge harness the only thing i dident write any notes on and its been 4 or so months can some one tell me what plugs are on it ? and where they go i no what wires are for the alt and starter what about the red connector and the black slide on plug in my hand.
Old Aug 5, 2011 | 07:05 PM
  #92
mrboost05's Avatar
has anybody else had problems with the mistumoto rad ? it leaves a decent size gap between it and the rad support i dont really like that i should have went with the cbrd rad but i have ran mistumoto rads before and they worked fine i always ran spal fans with them fitment is crapppy but its for a evo 7 so i cant expect much i guess .
Old Aug 8, 2011 | 10:23 AM
  #93
mrboost05's Avatar
well it was my bday sat so i decided to treat myself alittle
start
half way
all done
Old Aug 14, 2011 | 07:54 AM
  #94
mrboost05's Avatar
going to try to start her monday cant find my stock ignition so a buddy is going to let me borrow his sparktech.
Old Aug 14, 2011 | 11:22 AM
  #95
HyboostN's Avatar
I cut the middle tab on the bottom of the radiator off and it fits perfect.
Old Aug 14, 2011 | 11:26 AM
  #96
sr20detisbetter's Avatar
Nice project man....takes me back to building my 240s
Old Aug 14, 2011 | 09:24 PM
  #97
mrboost05's Avatar
awesome hyboosten ill try that and thanks sr20 so i found my stock ignition tonight it cranks but shes not turning over does anybody have a good diagram for wiring up a double pumper with both pumps all the time ? i wanna make sure i did mine right when i take the power wire stright to the batterie i hear the pumps but running thru the relay i dont think i have anything.
Old Aug 15, 2011 | 05:01 PM
  #98
mrboost05's Avatar
shes cranking but not starting ive figured out that i have have fuel to the rail but the injectors are not working the plugs/cylinders are dry as can be. no spark so i think its the rom on the ecu or the cam position sensor anyway to test it ?.
Old Aug 15, 2011 | 05:27 PM
  #99
ILoveAWD's Avatar
nice build love to see evos being built!
Old Feb 15, 2012 | 06:52 PM
  #100
mrboost05's Avatar
been awhile since i updated the car has been running good since the summer i got the itch to start working on it so i started to clean the bay up going to delete abs and tuck the fuse box.
plans:
aem v2 tuned by stm
spark tech cdi unit
stm abs delete
stm rad stays
tuck fuse box
double din headunit
before
Old Feb 15, 2012 | 06:54 PM
  #101
mrboost05's Avatar
and yesterdays work
Old Feb 20, 2012 | 04:41 AM
  #102
mrboost05's Avatar
so i pulled the harness out yesterday without taking the dash out i do not recommend doing it that way it took alot longer my back hurts alot more but since ive did it once and no what needs to be moved i am sure i could do faster ill add pics later the fun starts tonight.
Old Feb 20, 2012 | 05:08 AM
  #103
mrboost05's Avatar
thats the hole harness engine fusebox headlights ect tonight i will start mocking it up.
with the dash still in if you dont see it i had to remove it to get the harness out.
and my empty engine bay i thought about making some more changes but ill wait alittle bit and enjoy the car.
Old Feb 22, 2012 | 01:58 PM
  #104
DavidCLy's Avatar
looking good man gl with the rest of the build
Old Feb 23, 2012 | 06:31 PM
  #105
mrboost05's Avatar
any tips for getting the tob to release ?
