Dnetcrawler's 2012 GSR by AMS/IND/Bulletproof
Subscribe
Jan 23, 2013 | 01:12 PM
  #61
AMS CF Roof FTW!
Fall-Line Update
Seat Fitting. Not my seats BTW, just the crappy ones they use for fitment purposes.
Reply 0
Jan 23, 2013 | 01:25 PM
  #62
Moar!!!!!!!!
double post.
Reply 0
Jan 23, 2013 | 01:46 PM
  #63
damn, that's a badass roof!
Reply 0
Jan 24, 2013 | 07:15 AM
  #64
Fall-Line very impressive weld quality!
Reply 0
Jan 29, 2013 | 05:32 AM
  #65
Quote: Stage #1 Mods / Runfile_002:
AMS EVO X 750XP Turbo kit
AMS EVO X Upper Intercooler pipe / hot pipe powder coated black
AMS 2008+ Evo X FMIC Kit w/Logo
Injector Dynamics 1000cc High Impedance Injector Set
Deatschwerks DW65c Compact In-Tank Fuel Pump
GrimmSpeed Mitsubishi Boost Control Solenoid EVO X
HKS Hi-Power Exhaust System
Stage #2 Mods / Runfile_017:
AMS 2.4L Sleeved Block
AMS Spec Rods and pistons and billet Crank
AMS EVO X CNC Cylinder head
AMS Spec TMP Cams by Kelford
Exedy EVO X Triple Metallic HD Clutch Kit
AMS Evo X Clutch Master Cylinder Conversion Kit
AMS EVO X Adjustable FPR Kit
Boomba Aeromotive 340 lph Evo X Fuel Pump Drop in Kit
Cusco 15mm Hose Universal Catch Can
Is this the power with the 2.4 sleeved block or without? Just wondering because I know that ams has their 2.4 sleeved engines up to like 700 wheel power range and I want to go this same route.
Also just curious, why didn't you keep the te's instead of hre's since they are much lighter also a single exit exhaust would be much more beneficial in terms of weight savings too.
Reply 0
Jan 29, 2013 | 06:38 AM
  #66
Quote: Is this the power with the 2.4 sleeved block or without? Just wondering because I know that ams has their 2.4 sleeved engines up to like 700 wheel power range and I want to go this same route.
Runfile_002 has the numbers for the sleeved block. We are running this setup very conservative. With race fuel we are expecting to run between 600-650whp on the 5858 turbo. I could upgrade the turbo to a 6262 or 6266 and get the numbers you are looking for, but would sacrifice the spool a little. That said, I'm planning to run NASA ST1 so will probably not run more than 600whp or so.
As for the wheels, we wanted to run AD08 285/30, which required a wider wheel. I had 3 sets for TE37 already, and wanted something new. I had been eyeing the HREs for a long time, so figured it was time.
As for the weight difference, it's negligible:
HRE R43 18x10.5 19.8lbs
Volk TE37sl 18x10.5 19.6lbs
Reply 0
Jan 30, 2013 | 11:08 AM
  #67
Finally getting down to the wire. These are the only items I got left to do on the build:
Big Break Kit: Alcon, AP, Endless, or Brembo
Exhaust: Tomei or Akrapovic
Front Custom Splitter
Break Cooling Kit
Surge Tank?
Things we have added since the arrival at Fall-Line:
AIM MXL Pista with GPS and SmartyCam HD.
Hotchkis Swyabars and Heavy Duty Rear EndsLinks
Reply 0
Jan 30, 2013 | 12:45 PM
  #68
Nice looking build, look forward to seeing pics of the updates
Reply 0
Jan 30, 2013 | 12:57 PM
  #69
Quote: Finally getting down to the wire. These are the only items I got left to do on the build:
alcon or stoptech
the akrapovic is beautiful but carries some weight.
the tomei is the lightest and the single is nice especially if you build a rear diffuser. the bad part is it does neck down at the flanges near the cat.
maybe an option is to buy the tomei, cut off the flanges and weld on V-bands if your guys can weld Ti.
Reply 0
Jan 30, 2013 | 01:00 PM
  #70
Quote: maybe an option is to buy the tomei, cut off the flanges and weld on V-bands if your guys can weld Ti.
This is a great advice! Thanks!
Reply 0
Jan 30, 2013 | 01:14 PM
  #71
I'm I missing something? Are these weights correct?
Tomei Expreme Ti
34.5023 LBS
AKRAPOVIČ
30.4 LBS
Reply 0
Jan 30, 2013 | 01:27 PM
  #72
Quote: I'm I missing something? Are these weights correct?
Tomei Expreme Ti
34.5023 LBS
AKRAPOVIČ
30.4 LBS
that looks wrong. the tomei is like 11 pounds..
edit:
LANCER EVO 10: Stock is 20.05kg ( 44.2lbs) – Tomei Expreme Ti is 4.4kg ( 9.7lbs)
http://www.tomeipowered.com/BTE/inde...-ti-explained/
Reply 0
Jan 30, 2013 | 01:31 PM
  #73
Quote: that looks wrong. the tomei is like 11 pounds..
edit:
Is stand corrected! I knew something was wrong.
Reply 0
Feb 1, 2013 | 12:34 PM
  #74
Reply 0
Feb 28, 2013 | 11:32 AM
  #75
Hope these satisfy the hunger for now! Cage will be done next week
Reply 0
