deployment money funded- time to play
Old May 11, 2013 | 11:05 AM
Supergoslow's Avatar
Originally Posted by minimarine09
EU
^^^ thanks for the advice guys. So the car is Pitt back together, feels good. Needs an in depth tune bad. But tom hooked me up with something that will get me home for now. All i can say right now is, going from the stock clutch to Stg 3, lightweight flywheel,ss clutch line, AND taking the restrictor out in the slave cylinder is absolutely night and day...lol. I feel like an evo boot trying to drive around in this thing! I'll get used to it in time, but everything is going well so far. Break in time!!!!!!!!!!!!! ...
lol we put a stage 4 6-puck in my buddies evo and i went on leave, he called me like "dude i cant push the pedal down somethings wrong" but once you get it broken in and used to it you'll love it.
congrats on getting it running and together though! that's the best feeling in doing things on your own.
Old May 22, 2013 | 04:08 AM
minimarine09's Avatar
Ok so. Got some bad news. And something mysterious as well. So the drive to Tampa was going good. 1st 11 hours went great. The play hour the evo stopped accelerating. Then died when i pulled over and wouldn't start. It turns over as if the cas is UN plugged. Everything checks good, it was getting fuel and spark. Figured out the timing on my intake cam slipped about 4teeth. Did a compression test After re timing and it went something like 115-125-120-115. I didn't bother to put some oil in it because it was kind of obvious after the timing slipped it was bent valves. So i pulled the head the next day. Took it to a machine shop. And they found that NONE of the valves were bent... Has any one seen timing slip like that and not bend any valves? I did a hot compression test about a week earlier and everything was 175 across the board. So i don't think it was the rings. I'm a little confused. We do have interference motors correct? Even so, s2 cams have a good lift so in theory they should have slapped... Has anyone seen this before?
Old May 22, 2013 | 01:03 PM
your tensioner probably went which would've caused the slipped belt and your valves were probably open ever so slightly to lose compression but not hit the pistons. yes it's an interference engine however if you have stock pistons the reliefs are pretty big so you probably got lucky.
I could be wrong cus 4 teeth is a lot but that's my .02! be thankful you didn't mess anything up lol
Old Jun 13, 2013 | 08:51 AM
lol i know right! what a relief! no pun intended lol
ok so update: life has been pretty busy but in all the commotion ive managed to get my head back on, and all the timing stuff off. now im just waiting to buy my timing stuff ... "im not in a hurry to get the evo running" - my wife ... but i figured while it was down i might as well shave/ paint my valve cover and paint my headlights black. so one of my headlights is in the oven now. when i grinded off the lines on top of the valve cover, i gashed it pretty deep in a couple places. it took forever to sand down until everything was perfectly flat on both sides but i got it! im also debating on doing the "nose chop" mod aswell but that will most likely have to be another time. im pretty stoked to see how it all looks after. more to come! and PICS!
Old Jun 13, 2013 | 09:14 AM
towing from Tampa FL to NC with my "problem child" jeep lol-
i sanded one of my headlights with 91% rubbing alcohol it took the chrome paint off pretty good but since there are alot of little grooves in the headlights, it took forever! until i read up on a how to forum about this easy off spray, let it sit for 5 min, and sprayed off with a hose and it got every single piece of chrome off. life saver for sure-
finally got everything flat, you cant even tell that i gouged it pretty bad (i suck with table grinders) but with an electric sander and about 45min per side with 150 grit, its smooth as butter-
more pics to come!
Old Jul 5, 2013 | 02:43 PM
UPDATE: HAPPY LATE 4TH EVERYONE!!! everything is put back together and running perfectly so far. besides a bad iacv that im going to get in this week. but just got my wide band in and working along with my oil pressure gauge, im about 50 miles away from breaking in my clutch completely and start to get ready for power tuning!!! im stoked, i just have to post some recent pics up, my car desperately needs a wash so exterior shots will come later! lol
Old Jul 5, 2013 | 03:14 PM
is there any other reason to deploy? lol stay safe man, my buddy just hit an 80 pounder luckily him and everyones alright. and yes the driftwood is still there, distributing hepatitis and blue ***** evenly to all the new joins!
this just reminded me that this was our running password lol people just yelling DRIFTWOOD DRIFTWOOD lol
heres some more pics-
installed a new timing and balance belt, tensioned perfectly to spec, i would still like to clean up the engine bay alot more, deleting the sprayer and putting a custom catch can set up there. and im debating on putting a clear coat on the valve cover, grease tends to stcik to the grill paint that i used pretty good, i like the flat black look but having to try and rub off the grease every time is a pain, im starting not to care lol.
i took all the extra rtv off that is spilling over the edge that you can see in this pic. this one is just from initial start up after i got her together
just my 4th of july meal, stuffed burger with pepperoni, sausage, 3 difft cheeses, bacon, and jalapenos, and some other stuff lol once again, happy late 4th of july everyone!!! salute to the guys still out there defending our freedom this one is for you-
Old Oct 6, 2013 | 12:06 PM
Haha I might have to steal that from you. I just got my car back on the road! Unfortunately I had to head back to lejeune without it though but yours looks great man. Awesome progress.
Old Oct 6, 2013 | 12:20 PM
thanks man i appreciate it!
so for the car as it sits currently, im switching to speed density, car is sitting in the garage until i get back from cali. just bought a nice 4inch intake time to let the turbo breathe! lol im also contemplating on chopping the nose off of my bumper, any opinions?
Old Oct 18, 2013 | 10:58 AM
update-
i made the SD switch, as you can see i have my 4in intake with k&n filter, i already had my omni 4 bar, and im going to go with using the fuel temp sensor method instead of welding in an iat sensor in my uicp. all i need to get her running is my tune from tom. hes a busy guy! also went ahead and deleted my egr and my IC sprayer, took up too much room and weight.
so as she sits now!
i also sold my defi boost gauge and bought an aem boost gauge to finally match my other aem gauges (A/F, oil press on the steering column)-
my headlights a while after i finished painting them, i think they look great! and a hell of alot cheaper than buying jdm ones lol-
i also went ahead and routed my tactrix cable and w/b serial cable through the glove box so all i have to do to log is open my glove box and plug in, no more ugly wires hanging across everything. -
more to come!!!
Old Oct 18, 2013 | 02:13 PM
also debating on doing a full wire tuck, ive ben reading a how to on here. i just dont have a soldering iron at the moment. there is some shady looking areas around the engine bay with electrical tape, so im wondering how many surprises im going to run in to... im kinda scared lol
Old Oct 18, 2013 | 11:01 PM
Started the idle tuning today, the idle is pretty rock solid so far, im diggin it stoked to drive it tomorrow
Old Oct 18, 2013 | 11:18 PM
SloGST's Avatar
Yellow evos have really started to grow on me for some reason. Nice car man, same thing happened to the head on my car.
Old Oct 18, 2013 | 11:23 PM
i know what you mean! when i 1st got my evo i didnt like the yellow, but now it has definitely grown on me. thanks man, i appreciate it. ill be updating as i further tune
Old Oct 18, 2013 | 11:37 PM
SloGST's Avatar
Subbed, check out my thread here in the build section, its named 03 TB Evo 8. Also, thank you for your service to the country!
