My Evo6.5 TME build
Old Oct 6, 2013 | 11:05 AM
Kansaiplus's Avatar
My Evo6.5 TME build
Hello from Thailand.. I'm not new here but normally only view on classified forum looking for parts.
Here I have is my 2001 Mitsubishi Evo6.5 TME. I bought the car about a year ago it was bone stock and took me about a year to reach this step.
I never get a chance to put my car on dyno yet. Can anyone give me an idea how much whp should I expect with my set up and 30psi of boost.
Engine:
GSC S2 cams
GSC fidenza cam gears
GSC zero tick lifters
GSC 5041 Valvespring &Ti retainer
Exedy Single plate clutch
Evo 7 Gsr 5spd tranmission
Fp red 84mm bb turbo
Turbosmart dual port blow off
Cusco intake pipe K&N filter
Skunk2 intake manifold
S90 70mm throttle body
HKS 3in intercooler
HKS upper and lower intercooler pipes
HKS oilcooler
Koyorad aluminium radiator
Samco silicon all hose
ralliart 1.3psi radiator cap
AFI exhaust manifold ceremic coated
Custom o2 outlet
Custom 3in test pipe
5Zigen 3in exhaust
Perrin fuel rail
PTE 1000cc injectors
Aeromotive 340 fuel pump
Aeromotive regulate
Grimspeed 3ports EBCSboost controller
Okada plasma coils
Ralliart spark plug wires
NGK racing plug#8
OEM Evo9 head gasket
Arp head studs
Tomei thermostat killer
Mishimoto magnetic oil drain plug
Gate racing timing & balance belt
Cusco oil catch tank
Custom aluminium coolant reservoir tank
Billion power steering fluid tank
Ralliart Reservoir Brake reservoir tank Cover
Fuse&relay box stainless cover
Radiator billet aluminium brackets
Skunk2 battery tie down
OJOP quick battery connectors
CF hood dampers
CF Engine dampers
JMF cam sensor heatshield
ARC titanium sparkplug cover
ARC titanium radiator shield
Stock ECU Flashed boost 1.8 E20 pump gas
Interior:
Ralliart shiftknob
Ralliart pedal set
Ralliart foot rest
Ralliart 300kmh speedometer
cf gauge surround
cf A/C surround
Evo9mr OEM din gauges
Defi bf boost gauge
Defi bf fuel pres gauge
Defi bf oil temp gauge
Defi link unit
AEM Tru wideband gauge
Apex turbo timer
Suspension:
Tein HA coilovers
Cusco front upper strut bar
Cusco front lower arm bar
Cusco rear upper strut bar
Axis F\R brake pads
Exterior:
Tommi V4 front bumper
ganador side mirrors
Ralliart mud flaps
OEM wind Windsor
Comingsoon:
CF Voltex generator
OMP Ralliart limited 4champs steering wheel (If i can find one)
SPEC-R Alloy Brake Fluid Cap Cover
upgrade to a better set of coilovers
Any suggest mod ?
How many whp you guy think put out on this car now????
Thank for looking
Old Oct 6, 2013 | 11:12 AM
rjfg's Avatar
Haha I strongly dislike you for havibg suxh a beautiful car
I'd figure would 30lbs of boost on a fp red somewhere btwn 350 to 400hp if not more. Amwhat type of gas are you using?
That's a hell of a mod list! Onky thibg left is to build the bottom ebd or stroke the motor to a 2.3
Old Oct 6, 2013 | 11:55 AM
Kansaiplus's Avatar
Thank you
I'm using E20 gas here in Thailand, I believe it about the same grade as pump gas 93 octane over there.
I'm tossing an idea about to build a 2.3 as spare stroker bottom end or not incase if I break this block. Since I already have wiseco hd1400 just need to find rods and crank.
Old Oct 12, 2013 | 03:59 AM
Ang Wen Yan's Avatar
Thumb up for having a red EVO VI TME this clean
They are a sacred car nowadays
fugiwara
29
Jan 6, 2017 08:10 AM
fugiwara
Jun 11, 2016 03:50 PM
fugiwara
Jun 26, 2015 09:14 PM
fugiwara
Jun 20, 2015 12:52 PM
