Evo update
Old Dec 18, 2021 | 09:27 AM
  #106
CDrinkH2O's Avatar
What is the matt coating in the chambers and the clear coating on the sealing face of the head?
Old Dec 18, 2021 | 11:11 AM
  #107
CurseDSM's Avatar
The head is freshly surfaced that's why it looks like a clear coat. There is no coatings on the head other then on the valve faces and combustion chambers. The coating is called ThermBar.
Old Dec 21, 2021 | 07:13 AM
  #108
CurseDSM's Avatar
So I have been thinking about doing a Haltech ic7 for a few months now and I wanted to come up with a better solution then just having it mounted to my steering wheel and having my stock cluster behind it. I wasn't sure if the ic7 did all the functions that a stock cluster will do and it seems with the new updates it does. It now has features like turn signals, fuel level and things like that, that are needed in a street car. So with that said I was thinking about doing something like this. What do you guys think. This will allow me to not clutter up my dash with guages I don't need all in one spot.
Old Dec 21, 2021 | 07:20 AM
  #109
staywide8's Avatar
I wish I had you on Facebook. I have the dash installed in my 8 with everything working. I used the dash surround as well. Looks better than factory and works awesome.
Edit-added pics. Vid wont upload. Also, gauges ar now gone.
Old Dec 21, 2021 | 08:10 AM
  #110
CurseDSM's Avatar
Dude thats bad ***. Yeah I don't do social media at all.How much of a pita was it to get everything to work?
Old Dec 21, 2021 | 08:17 AM
  #111
staywide8's Avatar
I know most of the wiring setup-wouldnt be hard to duplicate. Still finessing the fuel sender. I'm close, just not perfect yet. You'll need a couple resistors too
Old Dec 21, 2021 | 08:36 AM
  #112
CurseDSM's Avatar
I don't see why it wont read off the stock wire coming from the sending unit itself. I have an aftermaket sending unit so I am sure they can tap onto that line and back to the ic7
Old Dec 21, 2021 | 08:38 AM
  #113
staywide8's Avatar
It does read off the sender. It's about knowing voltage levels to fuel levels
Old Dec 21, 2021 | 09:21 AM
  #114
CurseDSM's Avatar
Oh ok that works looks like 240 ohm resister is needed.
Old Dec 21, 2021 | 09:39 AM
  #115
staywide8's Avatar
Buy the haltech fuel conditioner, wire it in and I should have voltages set to give you at that point.
Old Dec 21, 2021 | 06:14 PM
  #116
CurseDSM's Avatar
dude thats bad ***. That makes things so much easier. Yeah let me know what you find I am paying off some bills and i will see what i can pay for when its all said and done.
Old Dec 22, 2021 | 09:32 AM
  #117
CurseDSM's Avatar
So I was talking to a MAP rep who has one of these in his car running a 2500 and he was telling me that you can run everything through the can stuff. He said he was going to make sure with the evo8 if how your doing it needs to be done that way or if the can stuff can work. I asked about the fuel conditioner and he said not needed that the Haltech uses the voltages in the ecu. Idk he said he has a buddy who works at Haltech and he is going to give him a call and tell me everything that needs to be done so I can confirm everything. Did you get your dash plastic from 3drs? I think they are the only ones who make a dash for the evo. If so how were they to work with?
Old Dec 22, 2021 | 12:14 PM
  #118
TimInselman's Avatar
I'm going to be installing this setup into my 8 soon any tips on the wiring for blinkers and Fuel gauge etc.?
Edit: I should of read more of the post before posting.
Old Dec 22, 2021 | 12:17 PM
  #119
I bought my surround from Mako Motorsports. it looks good but I'm not sure how it is for mounting as its not in my car yet. My buddy has a Aem Cd5 in his Integra with the Mako surround and it fits real nice..
Old Dec 22, 2021 | 12:34 PM
  #120
CurseDSM's Avatar
Reading from Haltech it says you can use the can plug in your ecu if your running a standalone and it will read the fuel level stuff. I am waiting on a call back and a conformation from Haltech to verify. Blinkers are hard wired into the back of the Ic7
