Going under the knife.. MAP 2.3L\EF4 Build
Dropping my car off at MAP tomorrow! Chris and the entire team have been great and I cannot wait to see the end result and final numbers.. predictions? :)
Mods ***UPDATED 2/15/12*** Performance\Engine: MAP 2.3L Stage 2 MAP EF4 Ported Turbo MAP Stage 1 Head MAP Ultimate Duty Rods MAP Ultimate Duty H11 Head Studs MAP 25psi Actuator MAP Custom Air Intake with Spectre Filter MAP Cam Sensor Shield MAP Custom UICP MAP Tubular Long Runner Exhaust Manifold MAP o2 Housing MAP AFPR Install Kit with AEM FPR Wiseco Pistons 1400HD GSC S2 Cams Beehive Springs ARP Main Studs ACL Bearings FP Exhaust Manifold Stud & Nut Kit AEM Tru-Time Cam Gear Zaklee Clear Cam Cover Gates Timing Belt SpoolinUP COP Speed Density FIC 2150cc Injectors MIL.SPEC TB Seals Walbro 400lph Fuel Pump Kenne Bell 40amp BAP EGR Blockoff ETS 3.5” FMIC Muse LICP Turbosmart 50mm Race Port BOV DC Sports Catless Downpipe GReddy Evo2 Catback Hallman Pro MBC Grimmspeed EBC Suspension: Robispec KW V3 Clubsports Robispec Rear Sway Bar Whiteline Front Roll Center Kit Whiteline Rear Trailing Arm Bushings Whiteline Rear Bump Steer Kit Vorshlag High Castor Front Camber Plates Stoppage: StopTech Slotted Rotors, front and rear Hawk HPS Front Pads StopTech Street Rear Pads StopTech Stainless Braided Lines Motul Fluid Trans: 5 Speed RS Swap with all new parts ACT HDG6 Competition Forged Steel Flywheel Speed Source Shifter Base and Cable Bushings Wheels\Tires: Summer: Enkei RPF1: 17x9.5 +18 front, +38 rear Falken Azenis RT-615k 255/40/17 Drop Engineering open-ended Lugs Winter: Stock MR BBS 225/45/17 Semperit Winter Sports Interior: Gruppe pod Prosport HALO Gauges-- Wideband, Oil Pressure, Boost Trustz Gauge Overlays LED bulbs Alpine CDA-105 Headunit Boston Acoustics SC65 Speakers Exterior: Evo 7 Tail Lights eBay Poly Lip Couple in progress shots: http://farm8.staticflickr.com/7156/6...90d2d37c_z.jpg http://farm8.staticflickr.com/7024/6...2fcaac04_z.jpg http://farm8.staticflickr.com/7154/6...b5231ccf_z.jpg http://farm8.staticflickr.com/7154/6...8afbcf4e_z.jpg |
I vote you join me at BiR for an HPDE this summer ^_^. Subscribed
Subscribed , thats going to be a killer setup.
subscribed... curious to see those EF4 results!
Nice good luck, they'll take good care of you.
I say mid to high 500 easily and probably around the same for torque if this is on E85. Your injectors are going to be forced hard though I feel. No head work?? |
Dropped off car at MAP today!
I am curious to see how the fuel plays out... I am guessing I will need Walbro 400, FPR and bigger injectors.. we'll see though. Head is getting MAP Stage 1 treatment. |
A few hours after dropping it off and motor\trans already out. I guess MAP has done this before. :P
https://farm8.staticflickr.com/7168/...2f2a130e_z.jpg https://farm8.staticflickr.com/7034/...4246856d_z.jpg https://farm8.staticflickr.com/7022/...dfdf7860_z.jpg https://farm8.staticflickr.com/7165/...13a98bac_z.jpg https://farm8.staticflickr.com/7001/...af9ceb04_z.jpg https://farm8.staticflickr.com/7002/...f6dc175e_z.jpg https://farm8.staticflickr.com/7155/...7f20cba3_z.jpg https://farm8.staticflickr.com/7025/...4ce5d372_z.jpg |
Heads off.. short block looks pretty good!!
https://farm8.staticflickr.com/7154/...00b06de6_z.jpg https://farm8.staticflickr.com/7027/...007398fa_z.jpg |
looking awesome mate :D
Coming along.. Clutch and flywheel got damaged when separating motor and trans. Bummer. I'll be going with an ACT HDG6 sprung and comp flywheel. Also upgrading fuel pump, injectors and adding a FPR.*
http://farm8.staticflickr.com/7019/6...658f311f_z.jpg http://farm8.staticflickr.com/7164/6...fda2b6ef_z.jpg |
{thumbup}
Looking good. I can't wait to see what kinda #'s your gonna make and how she performs definately subscribed.
This build looks simply AMAZING ! EXACTLY the type of build I would like to give my evo one day. Good luck bro and DEFINITELY sub'd
Thx
Also.. Check it.. *Even outside of the car with easy access and a multitude of tools there was no way the pressure plate was letting go without damaging the retaining ring :( http://farm8.staticflickr.com/7012/6...d57fc1ed_z.jpg |
should of released it while engine was in car.
