-   Project Cars / Build Threads (https://www.evolutionm.net/forums/project-cars-build-threads-344/)
-   -   Mr. Evo IX's 2013 MR Touring Build (https://www.evolutionm.net/forums/project-cars-build-threads/720153-mr-evo-ixs-2013-mr-touring-build.html)
Mr. Evo IX Oct 11, 2015 08:04 AM
Mr. Evo IX's 2013 MR Touring EFR7670 EWG Build
30 Attachment(s)
Part 1
AMS Intercooler
Cobb Upper and Lower IC piping
Cobb Inlet and Intake
Tanabe Concept G TBE
Cobb, scratch that Milspec High Flow Cat
Cobb 3-port BCS
Cobb V3 AP
ID 1000 Injectors
Walbro 450
E85 374wtq/356whp 93oct 339/314 ProTuned by Calvin
Eibach Prokit lowering springs
Ichiba 20mm bolt on spacers
Part 2
Borg Warner EFR 7670 EWG
Full Race T4 EWG kit w/Ceramic Coating
Full Race Upper and Lower IC piping
Full Race 3.5" Intake
Full Race Vband Dump Tubes
(2) 38mm Tial Wastegates
Aluminum Valve Cover
Driven Fabrication V3 AN10 Catch Can
Boost Resource Manifold, Turbo, and DP Blankets
AEM Uego Wideband
Part 1 (Cobb Stage 3 + Fuel System)
Attachment 271835
Showroom Floor 2013 Evo X MR Touring
Attachment 271836
Stock Exhaust removed
Attachment 271837
Cobb Hi-Flow cat, this has since been sold and replaced with a Mil-Spec Hi-Flow cat
Attachment 271838
Attachment 271839
Tanabe Concept G Resonated exhaust
Attachment 271840
Cobb AP (Missing NAV knob finally replaced by dealer)
Attachment 271841
Baseline tune (Stock mapping with aftermarket exhaust compared to Stage 2 OTS mapping)
Attachment 271842
Parts stacking up in the hallway
Attachment 271843
Disassembly
Attachment 271844
Bumper off
Attachment 271845
Bumper
Attachment 271846
Test fitting
Attachment 271847
Cobb 3port BCS
Attachment 271848
AMS FMIC
Attachment 271849
AMS FMIC fitting
Attachment 271850
LICP fitting
Attachment 271851
LICP fitting
Attachment 271852
Dirverter valve pipe
Attachment 271853
BCS plumbed
Attachment 271854
Upper pipe installed
Attachment 271855
Inlet and intake pipe installed
Attachment 271856
Walbro 450
Attachment 271857
Cobb ID1000 fuel injectors
Attachment 271858
E85 and pump gas custom mapping by Calvin @ Cobb Plano
Attachment 271859
Delta
Attachment 271860
Eibach prokit installed, looks like a hovercraft
Attachment 271861
Attachment 271862
Attachment 271863
How she looks now
Attachment 271864
Coming soon!!!
Mr. Evo IX Oct 11, 2015 08:05 AM
28 Attachment(s)
Part 2
Attachment 271807
The gathering of parts!
Attachment 271808
EFR 7670
Attachment 271809
Attachment 271810
Attachment 271811
Loosely clocked
Attachment 271812
What a beautiful Turbo
Attachment 271813
Safety first
Attachment 271814
Dismantling Cobb bolt-ons
Attachment 271815
Strut bar, heat shields, and BOV pipe removed
Attachment 271816
Soaking in PB Blaster
Attachment 271817
Friend helping out, thanks for friends!
Attachment 271818
Most useful tools of the day!
Attachment 271819
Impact tool makes easy work of easy to reach bolts (posed)
Attachment 271820
Attachment 271821
Time to go underneath, on Jackstands
Attachment 271822
Tray removed
Attachment 271823
Bumper removed
https://i177.photobucket.com/albums/...ad/build47.jpg
https://i177.photobucket.com/albums/...ad/build48.jpg
DP Removed
There were a lot of bolts removed between this photo and the next one including the "***** Bolts" (Upper and Lower Turbine Brackets)
Water lines and oil lines were removed as well
Attachment 271824
Manifold removed
Attachment 271825
Turbo almost ready to come out, actually I tried to just pull it out like this.
Attachment 271826
going in for surgery
Attachment 271827
I removed the housing in the car then it came out very easily
Attachment 271828
Empty.. lots of space now
Attachment 271829
Unwrapped the new manifold.. pretty
Attachment 271830
Nice welds, nice bolts and washers
Attachment 271831
Attachment 271832
Test fitting boost resource heat protection, certainly hides the beauty of what's inside. Function first.
Attachment 271833
Looks different than some that I've seen online, very tight fit, this may be difficult to get on later.
Attachment 271834
Cutting gold foil for heat protection
6 Attachment(s)
Attachment 271801
More gold foil wrapping
Attachment 271802
Test fitting manifold, scratched it a little, should have gotten some tape.. oops.
Attachment 271803
Test fitting turbo, center section is going to have to be rotated back
Attachment 271804
Required
Attachment 271805
Fitting, this coupler is a little too close to that EWG for my liking
Attachment 271806
More test fitting
Too be continued, I'm pausing right now to see what Full Race can do about the turbo outlet coupler being so close to the external wastegate, I still need to test fit the
dump tubes as well but I need the car back on jackstands for that.
9 Attachment(s)
Attachment 271792
Dump Tubes and Boost Resource DP heat protection
Attachment 271793
Attachment 271794
Dump Tubes from the top
Attachment 271795
Wastegates plumbed, new upper pipe in photo
Attachment 271796
Attachment 271797
Valve cover installed
Attachment 271798
Driven Fabrication Catchcan
Attachment 271799
Driven Fabrication Fitting
Attachment 271800
Charge piping installed
MisterNickG Oct 11, 2015 09:22 AM
Nice work dude, can't wait to see more updates. I'm subscribing to this!
txmrguy Dec 14, 2015 08:15 AM
Amazing, update?
TWM Performance Dec 14, 2015 08:53 AM
Wow the appearance of the engine bay is amazing
- Renato
Mr. Evo IX Mar 10, 2016 03:40 AM
3 Attachment(s)
Attachment 268327
Pretty much complete other than the boost resource manifold blanket.
Attachment 268328
Strapped down and ready to go.
Attachment 268329
430whp / 357ft/lbs @ 26.5psi on 93oct
Mr. Evo IX Mar 10, 2016 03:42 AM
Car needs cams.. I'll post up some video after editing. The dumps are LOUD.
NJ9MR Mar 10, 2016 05:19 AM
Nice, Congrats! Thanks for sharing! Best of luck!
Mr. Evo IX Mar 12, 2016 03:57 AM
I think this was one of the first runs through the gears after WOT tuning was completed.
bosoup May 24, 2016 09:21 PM
Dope!
